I’m working on the same issue as @Edward described in this post:
I can launch my M4 firmware without any issues from u-boot with the bootaux command.
Now I try to switch launching the firmware form our Linux host.
- With my modifications shown bottom, I’m able to launch the M4 firmware form linux as many times I need it
- But when I load my linux kernel module
insmod imx_rpmsg_tty.kono RPMSG device is enumerated under/dev/ - If I initially launch the M4 firmware from u-boot I’m also able to reprogramm the firmware with remoteproc and the
insmod imx_rpmsg_tty.koenumerates the required device as/dev/ttyRPMSG0
My Setup:
- Colibri iMX7d on customer specifc hardware
- Linux Kernel: git://git.toradex.com/linux-toradex.git on branch toradex_5.4-2.3.x-imx
- U-Boot 2020.07 : git://git.toradex.com/u-boot-toradex.git on branch toradex_2020.07
The relevant parts of my top level devicetree
reserved-memory {
#address-cells = <1>;
#size-cells = <1>;
ranges;
cm4tcmcode: cm4tcmcode@0x7f8000 {
compatible = "shared-dma-pool";
reg = <0x007f8000 0x8000>;
no-map;
cm4sramcode: cm4sramcode@0x900000 {
reg = <0x00900000 0x40000>;
no-map;
imx7d-cm4 {
compatible = "fsl,imx7d-cm4", "syscon";
clocks = <&clks IMX7D_ARM_M4_ROOT_CLK>;
syscon = <&src>;
nombox = "true"; // Extension making mailboxes optional in drivers/remoteproc/imx_rproc.c
// Mailboxes for rproc have a resource conflict with mailboxes from imx_rpmsg, we can not use both
//mbox-names = "tx", "rx", "rxdb";
//mboxes = <&mu 0 1 &mu 1 1 &mu 3 1>;
memory-region = <&cm4sramcode>, <&cm4tcmcode>;
&mu {
&rpmsg {
memory-region = <&rpmsg_reserved>;
reg = <0x8fff0000 0x10000>;
My imx_rproc.c patch
drivers/remoteproc/imx_rproc.c | 31 ++++++++++++++++++++-----------
1 file changed, 20 insertions(+), 11 deletions(-)
diff --git a/drivers/remoteproc/imx_rproc.c b/drivers/remoteproc/imx_rproc.c
index 4a4324fb5975..d9336b807350 100644
--- a/drivers/remoteproc/imx_rproc.c
+++ b/drivers/remoteproc/imx_rproc.c
@@ -1164,6 +1164,7 @@ static int imx_rproc_probe(struct platform_device *pdev)
const char *fw_name = NULL;
int ret;
int i __maybe_unused;
+ bool nombox;
regmap = syscon_regmap_lookup_by_phandle(np, "syscon");
if (IS_ERR(regmap)) {
@@ -1212,10 +1213,14 @@ static int imx_rproc_probe(struct platform_device *pdev)
INIT_DELAYED_WORK(&(priv->rproc_work), imx_rproc_vq_work);
- ret = imx_rproc_xtr_mbox_init(rproc);
- if (ret) {
- if (ret == -EPROBE_DEFER)
- goto err_put_rproc;
+ nombox = of_property_read_bool(np, "nombox");
+ if(!nombox) {
+ ret = imx_rproc_xtr_mbox_init(rproc);
+ if (ret) {
+ if (ret == -EPROBE_DEFER)
+ goto err_put_rproc;
priv->clk = devm_clk_get_optional(dev, NULL);
@@ -1235,9 +1240,11 @@ static int imx_rproc_probe(struct platform_device *pdev)
goto err_put_rproc;
- ret = imx_rproc_db_channel_init(rproc);
- if (ret)
- goto err_put_mbox;
+ if(!nombox) {
+ ret = imx_rproc_db_channel_init(rproc);
+ if (ret)
+ goto err_put_mbox;
#ifdef CONFIG_IMX_SCU
priv->proc_nb.notifier_call = imx_rproc_partition_notify;
@@ -1352,10 +1359,12 @@ static int imx_rproc_probe(struct platform_device *pdev)
if (!priv->early_boot)
clk_disable_unprepare(priv->clk);
err_put_mbox:
- if (!IS_ERR(priv->tx_ch))
- mbox_free_channel(priv->tx_ch);
- if (!IS_ERR(priv->rx_ch))
- mbox_free_channel(priv->rx_ch);
+ if(!nombox) {
+ if (!IS_ERR(priv->tx_ch))
+ mbox_free_channel(priv->tx_ch);
+ if (!IS_ERR(priv->rx_ch))
+ mbox_free_channel(priv->rx_ch);
err_put_rproc:
rproc_free(rproc);
GitLab
I patched the u-boot as follows:
--- a/board/toradex/colibri_imx7/colibri_imx7.c
+++ b/board/toradex/colibri_imx7/colibri_imx7.c
@@ -284,11 +284,15 @@ int checkboard(void)
#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP)
int ft_board_setup(void *blob, bd_t *bd)
#if defined(CONFIG_IMX_BOOTAUX) && defined(CONFIG_ARCH_FIXUP_FDT_MEMORY)
int up;
- up = arch_auxiliary_core_check_up(0);
- if (up) {
+ // up = arch_auxiliary_core_check_up(0);
+ // if (up) {
int ret;
int areas = 1;
u64 start[2], size[2];
@@ -312,14 +316,17 @@ int ft_board_setup(void *blob, bd_t *bd)
eprintf("Cannot set usable memory\n");
return ret;
- } else {
+ // } else {
int off;
off = fdt_node_offset_by_compatible(blob, -1,
"fsl,imx7d-rpmsg");
- if (off > 0)
- fdt_status_disabled(blob, off);
+ fdt_status_okay(blob,off);
#endif
I enabled some debug messages within the relevant kernel drivers.
If I launch the firmware form u-boot the kernel log output looks like this
dmesg | grep 'mu\|rpmsg'
[ 0.001470] arch_timer: multiple nodes in dt, skipping
[ 0.001775] pid_max: default: 32768 minimum: 301
[ 0.048969] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.049395] imx7d-pinctrl 302c0000.iomuxc-lpsr: initialized IMX pinctrl driver
[ 0.050079] imx7d-pinctrl 30330000.iomuxc: initialized IMX pinctrl driver
[ 0.051097] imx mu driver is registered.
[ 0.051557] imx-rpmsg 8fff0000.rpmsg: dev doesn't have specific DMA pool.
[ 0.051569] imx-rpmsg 8fff0000.rpmsg: imx_rpmsg_probe rpdev vdev1: vring0 0x8fff0000, vring1 0x8fff8000
[ 0.051596] virtio virtio0: imx_rpmsg_set_status new status: 1
[ 0.051835] imx rpmsg driver is registered.
[ 0.052969] MU is ready for cross core communication!
[ 0.081737] virtio_rpmsg_bus virtio0: imx_rpmsg_set_status new status: 2
[ 0.081791] imx-rpmsg 8fff0000.rpmsg: vring0: phys 0x8fff0000, virt 0x(ptrval)
[ 0.081834] imx-rpmsg 8fff0000.rpmsg: vring1: phys 0x8fff8000, virt 0x(ptrval)
[ 0.082114] virtio_rpmsg_bus virtio0: buffers: va (ptrval), dma 0x92040000
[ 0.082354] virtio_rpmsg_bus virtio0: imx_rpmsg_set_status new status: 4
[ 0.082386] imx_mu 30aa0000.mu: isr: status: 00f00200 ctrl: 4c400000
[ 0.082406] imx_mu 30aa0000.mu: isr: status: 00f00200 ctrl: 4c000000
[ 0.082416] imx_mu 30aa0000.mu: isr: status: 04f00200 ctrl: 4c000000
[ 0.082431] imx_mu 30aa0000.mu: isr: status: 04f00200 ctrl: 4c000000
[ 0.082440] imx_mu 30aa0000.mu: isr: status: 04f00200 ctrl: 4c000000
[ 0.082457] imx_mu 30aa0000.mu: isr: status: 00f00200 ctrl: 4c000000
[ 0.082475] imx-rpmsg 8fff0000.rpmsg: rpmsg_work_handler msg: 0x0
[ 0.082491] virtio_rpmsg_bus virtio0: From: 0x0, To: 0x35, Len: 40, Flags: 0, Reserved: 0
[ 0.082504] rpmsg_virtio RX: 00 00 00 00 35 00 00 00 00 00 00 00 28 00 00 00 ....5.......(...
[ 0.082514] rpmsg_virtio RX: 72 70 6d 73 67 2d 6f 70 65 6e 61 6d 70 2d 64 65 rpmsg-openamp-de
[ 0.082524] rpmsg_virtio RX: 6d 6f 2d 63 68 61 6e 6e 65 6c 00 00 00 00 00 00 mo-channel......
[ 0.082531] rpmsg_virtio RX: 00 00 00 00 00 00 00 00 ........
[ 0.082543] NS announcement: 72 70 6d 73 67 2d 6f 70 65 6e 61 6d 70 2d 64 65 rpmsg-openamp-de
[ 0.082572] virtio_rpmsg_bus virtio0: creating channel rpmsg-openamp-demo-channel addr 0x0
[ 0.082700] virtio_rpmsg_bus virtio0: Received 1 messages
[ 0.082725] imx_mu 30aa0000.mu: isr: status: 00f00200 ctrl: 4c400000
[ 0.082736] imx_mu 30aa0000.mu: isr: status: 00f00200 ctrl: 4c000000
[ 0.082745] imx_mu 30aa0000.mu: isr: status: 00f00200 ctrl: 4c000000
[ 0.082757] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 0.082769] virtio_rpmsg_bus virtio0: imx_rpmsg_set_status new status: 4
cat /sys/firmware/devicetree/base/soc/aips-bus@30800000/rpmsg/status
okay
cat /proc/interrupts | grep imx_mu
53: 3 0 GPCV2 88 Edge imx_mu_chan[0-1], imx_mu_chan[1-1], imx_mu_chan[3-1], imx-mu-lp
after insmod imx_rpmsg_tty.ko
[ 132.349130] imx_rpmsg_tty virtio0.rpmsg-openamp-demo-channel.-1.0: new channel: 0x400 -> 0x0!
[ 132.349358] Install rpmsg tty driver!
[ 132.349376] imx_rpmsg_tty virtio0.rpmsg-openamp-demo-channel.-1.0: TX From 0x400, To 0x0, Len 12, Flags 0, Reserved 0
[ 132.349391] rpmsg_virtio TX: 00 04 00 00 00 00 00 00 00 00 00 00 0c 00 00 00 ................
[ 132.349400] rpmsg_virtio TX: 68 65 6c 6c 6f 20 77 6f 72 6c 64 21 hello world!
[ 132.349432] imx_mu 30aa0000.mu: isr: status: 00700200 ctrl: 4c400001
[ 132.349448] imx_mu 30aa0000.mu: isr: status: 00700200 ctrl: 4c000001
[ 132.349458] imx_mu 30aa0000.mu: isr: status: 00700200 ctrl: 4c000001
53: 4 0 GPCV2 88 Edge imx_mu_chan[0-1], imx_mu_chan[1-1], imx_mu_chan[3-1], imx-mu-lp
ls /dev/ | grep RPMSG
ttyRPMSG0
The RPMSG tty device is enumerated
If I launch the firmware from linux with remoteproc
[ 0.001474] arch_timer: multiple nodes in dt, skipping
[ 0.001777] pid_max: default: 32768 minimum: 301
[ 0.048755] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.049181] imx7d-pinctrl 302c0000.iomuxc-lpsr: initialized IMX pinctrl driver
[ 0.049817] imx7d-pinctrl 30330000.iomuxc: initialized IMX pinctrl driver
[ 0.050883] imx mu driver is registered.
[ 0.051340] imx-rpmsg 8fff0000.rpmsg: dev doesn't have specific DMA pool.
[ 0.051352] imx-rpmsg 8fff0000.rpmsg: imx_rpmsg_probe rpdev vdev1: vring0 0x8fff0000, vring1 0x8fff8000
[ 0.051380] virtio virtio0: imx_rpmsg_set_status new status: 1
[ 0.051614] imx rpmsg driver is registered.
[ 0.052745] MU is ready for cross core communication!
[ 0.081576] virtio_rpmsg_bus virtio0: imx_rpmsg_set_status new status: 2
[ 0.081631] imx-rpmsg 8fff0000.rpmsg: vring0: phys 0x8fff0000, virt 0x(ptrval)
[ 0.081676] imx-rpmsg 8fff0000.rpmsg: vring1: phys 0x8fff8000, virt 0x(ptrval)
[ 0.081954] virtio_rpmsg_bus virtio0: buffers: va (ptrval), dma 0x92040000
[ 0.082194] virtio_rpmsg_bus virtio0: imx_rpmsg_set_status new status: 4
[ 0.110175] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 0.110191] virtio_rpmsg_bus virtio0: imx_rpmsg_set_status new status: 4
okay
53: 0 0 GPCV2 88 Edge imx_mu_chan[0-1], imx_mu_chan[1-1], imx_mu_chan[3-1], imx-mu-lp
after:
- programming the m4 firmware through sysfs
/sys/class/remoteproc/remoteproc0/firmware insmod imx_rpmsg_tty.ko
further kernel logs after module insert
[ 73.994006] imx_mu 30aa0000.mu: isr: status: 00700200 ctrl: 4c400001
[ 73.994019] imx_mu 30aa0000.mu: isr: status: 00700200 ctrl: 4c000001
[ 73.994027] imx_mu 30aa0000.mu: isr: status: 00700200 ctrl: 4c000001
[ 73.994037] imx_mu 30aa0000.mu: isr: status: 04700200 ctrl: 4c000001
[ 73.994045] imx_mu 30aa0000.mu: isr: status: 04700200 ctrl: 4c000001
[ 73.994056] imx_mu 30aa0000.mu: isr: status: 00700200 ctrl: 4c000001
[ 74.017431] imx-rpmsg 8fff0000.rpmsg: rpmsg_work_handler msg: 0x0
53: 2 0 GPCV2 88 Edge imx_mu_chan[0-1], imx_mu_chan[1-1], imx_mu_chan[3-1], imx-mu-lp
I hope I provided enugh information and somone can point me to the right direction
Thanks in advice
