We are using Colibri iMX7 1GB eMMC (v1.1B, PID: 39) with a custom yocto image BSP 5.7.1 and are trying to figure out how to reflash a module once deployed if needs be. Once deployed we only have access to SSH and modules ip.
Idea was to use Boot from a TFTP/NFS Server.
We have gotten as far as configuring DHCP, TFTP and getting the module to boot EasyInstaller from it.
Once EasyInstaller boots we are greeted with a error message “Reading the Toradex Config Block failed…”, continuing we get to Config options where we need to select module type, version and serial.
For module type there is no option to select Colibri iMX7 1GB eMMC (39). There are only 512MB version and no eMMC.
Just to see what happens we selected iMX7D 512MB and we got to the interface for image selection.
Trying to Flash or Erase flash we are greeted by
flash_erase: error!: /dev/
error 21 (Is a directory)
We are able to flash EasyInstaller over usb in recovery mode and everything works normally.
We have downloaded new version of EasyInstaller 5.7.5_b19, also tried with 1.8.
Extracted tezi.itb and copied it to /srv/tftp/.
Created custom boot.scr and copied it to /srv/tftp/
/srv/nfs/rootfs/ is empty.
setenv bootargs console=ttymxc0,115200 quiet video=DPI-1:640x480D video=HDMI-A-1:640x480-16@60D video=LVDS-1:d video=VGA-1:640x480-16@60D rootfstype=squashfs root=/dev/ram autoinstall ${teziargs}
# Reenable fdt relocation since in place fdt edits corrupt the ramdisk
# in a FIT image...
setenv fdt_high
# Load FIT image from location as detected by distroboot
tftp ${ramdisk_addr_r} ${prefix}tezi.itb
bootm ${ramdisk_addr_r}
# mkimage -A arm -O linux -T script -C none -a 0 -e 0 -n "Distro Boot Script" -d boot.cmd boot.scr
DHCP config
# option definitions common to all served networks...
option domain-name "colibri.net";
option domain-name-servers 8.8.8.8;
default-lease-time 600;
max-lease-time 7200;
# Use this to enable / disable dynamic dns updates globally.
ddns-update-style none;
# Use this to send dhcp log messages to a different log file (you also
# have to hack syslog.conf to complete the redirection).
log-facility local7;
subnet 192.168.10.0 netmask 255.255.255.0 {
default-lease-time 86400;
max-lease-time 86400;
option broadcast-address 192.168.10.255;
option domain-name-servers 192.168.10.29;
option ip-forwarding off;
option routers 192.168.10.77;
option subnet-mask 255.255.255.0;
interface ens33;
#range 192.168.10.48 192.168.10.50;
#MAC address dependent IP assignment, used for the toradex target device
host eval {
filename "zImage";
fixed-address 192.168.10.244;
hardware ethernet 00:14:2d:e8:8e:25;
next-server 192.168.10.77;
option host-name "colibri";
option root-path "192.168.10.77:/srv/nfs/rootfs,wsize=1024,rsize=1024,v3";
