Imx7 SPI Problem
Hi all,
I am trying to get SPI working, I have changed my top level device tree file with the following settings:
&ecspi3 {
	mcp2515: can@0 {
		compatible = "microchip,mcp2515";
		pinctrl-names = "default";
		pinctrl-0 = <&pinctrl_can_int>;
		reg = <0>;
		clocks = <&clk16m>;
		interrupt-parent = <&gpio5>;
		interrupts = <2 IRQ_TYPE_EDGE_FALLING>;
		spi-max-frequency = <10000000>;
		status = "disabled";
	spidev0: spidev@0 {
		compatible = "toradex,evalspi";
		reg = <0>;
		spi-max-frequency = <23000000>;
I then compiled the spidev_test.c program with the cross compiler. When I run the compiled code on my platform I do not get any output on the SPI lines. The output when I run the code looks like this:
root@colibri-imx7-emmc:~# ./spitest1 -D /dev/spidev2.0 -p "1234"
spi mode: 0x0
bits per word: 8
max speed: 500000 Hz (500 KHz)
RX | 00 00 00 00 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __  | ....
The output from dmesg with reference to SPI looks like this:
[ 1.039537] spi_imx 30840000.ecspi:
dma setup error -19, use pio [
1.048391] spi_imx 30840000.ecspi: probed
I am expecxting to see SPI activity on pins 86,88,90,92, but there is nothing.
Does anybody have any tips on this topic?
Hi @eoin_oc
You have two devices on the same chip select (mcp2515 and spidev0 both reg=<0>;). I guess this should be different. Also you should define the chip selects similar to what we do here (line 86+):
Further I guess you should set the pinctrl in ecspi3 as in the example above and not on the device itself. Also please test what happens if you only add a spidev and no mcp2515.
Stefan
Thanks for the tips, i will try that,it is tricky to figure out as I have no idea what reg stands for?
It seems that this variable is named very poorly
Thanks for the feedback! Unfortunately Toradex has no influence on the naming convention in the devicetree.
