Hi all
I would like to know how I can play multiple audio files in parallel using aplay.
Does anybody know how to configure this? Should the default Toradex Linux Kernel support this?
Hi all
Hi @eoin_oc
As far as I know alsa can only handle one source. Therefore, normally pulseaudio should be used on top of alsa which then allows to mix several different sources together:
https://en.wikipedia.org/wiki/PulseAudio
Stefan
