We are trying to change screen resolution (frop 600x480 to 800x480) without success.
Context
- [00331102] colibri iMX7D 512MB V1.1C
- [12041000] EDT 7.0’’ TFT WVGA with Touch V1.0A
- Angstrom v2016.12 and Linux Image v2.7
Reference sources
- How to change the resolution on the Colibri iMX7 - Technical Support - Toradex Community → dts files are different (no #if in code)
- Display Output, Resolution and Timings (Linux) | Toradex Developer Center
Tasks done
- Download code git clone -b toradex_4.1-2.0.x-imx git://git.toradex.com/linux-toradex.git
- Configure toolchain and gcc-linaro
- Modify file arch/arm/boot/dts/imx7-colibri-eval-v3.dtsi, setting native-mode as &timing_wvga
- Recompile device tree (make dtbs)
- Copy imx7d-colibri-eval-v3.dtb under SD and reboot
- Check that new .dtb file is loaded using printenv command but videomode is still configured 640x480
videomode=video=ctfb:x:640,y:480,depth:18,pclk:39722,le:48,ri:16,up:33,lo:10,hs:
96,vs:2,sync:0,vmode:0
Is anything else required? Thanks in advance
