I have to turn the touchscreen 90 ° in real time. With xinput I can turn the touch. But xrandr works only in normal position.
*xrandr --output default --rotation left
xrandr: output default can not use rotation "left" reflection "none"*
or
*xrandr -o left
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 139 (RANDR)
Minor opcode of failed request: 2 (RRSetScreenConfig)
Serial number of failed request: 14
Current serial number in output stream: 14*
The application runs with Qt5, but without QML. QML would be a major change and I do not know if the imx6ull is suitable for it.
root @ colibri-imx6ull-00142d60611d: ~ # xrandr -v
xrandr program version 1.5.0
RandR extension missing
The Linux was created from the current TORADEX Yocto sources.
Angstrom v2017.12 - Kernel
Colibri-iMX6ULL_estec-image 2.8b4 20181230
The application is a portable measuring device.
I use my own hardware, which is based on the viola board V1.2.
The touchscreen is an EastRising ER-TFT043-3 / ER-TP043-3. The touch is resistive. The connection takes place as with your TFTs (18-bit RGB + TCON)
