Imx6ull restart network after changing ip address
So i can change the IP address of eth0 using
ifconfig eth0 192.168.1.55
and the network interface changes BUT i have to unplug and then reinsert the network lead to get it to be recognised on the network.
Is there a command i need to issue after the ifconfig to get the network to ‘restart’ so i do not need to unplug and then reinsert the lead ?
I found the way to do this without unplugging the lead is
ifconfig eth0 down
ifconfig eth0 up
Greetings @adrian!
Our BSP images are shipped with connman for managing network interfaces.
Can you please try using that to configure your IP address? Refer to this article for instructions.
Hi @adrian,
Please be aware that this also depends on other network properties.
Here in my local network, as soon as I change the IP, even with the cable plugged in, the properties are applied at the same time.
André Curvello
Perfect
You are welcome.
