I haven’t changed the device tree nor the kernel. I’ve used the the files from the available Image
Colibri-iMX6ULL_LXDE-Image-Tezi_2.8b6.184.
Here follows my boot log. Is this what you need?
root@colibri-imx6ull:~# dmesg
[ 0.000000] Linux version 4.9.166-2.8.6+gd899927728be (oe-user@oe-host) (gcc version 7.3.0 (GCC) ) #1 SMP Mon Apr 1 14:10:54 UTC 2019
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt:Machine model: Toradex Colibri iMX6ULL 512MB on Colibri Evaluation Board V3
[ 0.000000] Reserved memory: created CMA memory pool at 0x98000000, size 128 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 131072
[ 0.000000] free_area_init_node: node 0, pgdat 80c5fcc0, node_mem_map 97bb8000
[ 0.000000] Normal zone: 1024 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 131072 pages, LIFO batch:31
[ 0.000000] percpu: Embedded 14 pages/cpu @97b8e000 s25804 r8192 d23348 u57344
[ 0.000000] pcpu-alloc: s25804 r8192 d23348 u57344 alloc=14*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
[ 0.000000] Kernel command line: user_debug=30 ubi.mtd=ubi root=ubi0:rootfs rw rootfstype=ubifs ubi.fm_autoconvert=1 console=tty1 console=ttymxc0,115200n8 consoleblank=0 video=mxsfb:640x480M-16@60
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 376188K/524288K available (7168K kernel code, 386K rwdata, 2204K rodata, 1024K init, 376K bss, 17028K reserved, 131072K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xa0800000 - 0xff800000 (1520 MB)
[ 0.000000] lowmem : 0x80000000 - 0xa0000000 ( 512 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x80800000 (8160 kB)
[ 0.000000] .init : 0x80b00000 - 0x80c00000 (1024 kB)
[ 0.000000] .data : 0x80c00000 - 0x80c60860 ( 387 kB)
[ 0.000000] .bss : 0x80c62000 - 0x80cc0188 ( 377 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Switching to timer-based delay loop, resolution 333ns
[ 0.000017] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
[ 0.000058] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[ 0.003565] Console: colour dummy device 80x30
[ 0.004855] console [tty1] enabled
[ 0.004924] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[ 0.005033] pid_max: default: 32768 minimum: 301
[ 0.005290] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.005368] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.006875] CPU: Testing write buffer coherency: ok
[ 0.007564] Setting up static identity map for 0x80100000 - 0x80100058
[ 0.010727] Brought up 1 CPUs
[ 0.010811] SMP: Total of 1 processors activated (6.00 BogoMIPS).
[ 0.010871] CPU: All CPU(s) started in SVC mode.
[ 0.012488] devtmpfs: initialized
[ 0.036920] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.037739] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.037877] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.048212] pinctrl core: initialized pinctrl subsystem
[ 0.050839] NET: Registered protocol family 16
[ 0.064170] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.067257] cpuidle: using governor menu
[ 0.111560] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.111680] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.114190] imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[ 0.115090] imx6ul-pinctrl 2290000.iomuxc-snvs: initialized IMX pinctrl driver
[ 0.172938] mxs-dma 1804000.dma-apbh: initialized
[ 0.176016] soc_in: supplied by +V3.3
[ 0.176889] eth_phy: supplied by +V3.3
[ 0.180014] VCC_USB[1-4]: supplied by 5V
[ 0.183082] SCSI subsystem initialized
[ 0.183787] usbcore: registered new interface driver usbfs
[ 0.184034] usbcore: registered new interface driver hub
[ 0.184350] usbcore: registered new device driver usb
[ 0.186871] i2c i2c-0: IMX I2C adapter registered
[ 0.186967] i2c i2c-0: can't use DMA, using PIO instead.
[ 0.188439] i2c i2c-1: IMX I2C adapter registered
[ 0.188535] i2c i2c-1: can't use DMA, using PIO instead.
[ 0.188995] Linux video capture interface: v2.00
[ 0.189167] pps_core: LinuxPPS API ver. 1 registered
[ 0.189231] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.189382] PTP clock support registered
[ 0.190197] Advanced Linux Sound Architecture Driver Initialized.
[ 0.193234] clocksource: Switched to clocksource mxc_timer1
[ 0.193561] VFS: Disk quotas dquot_6.6.0
[ 0.193741] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.219565] NET: Registered protocol family 2
[ 0.221058] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.221244] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.221445] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.221623] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.221729] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.222102] NET: Registered protocol family 1
[ 0.223129] RPC: Registered named UNIX socket transport module.
[ 0.223352] RPC: Registered udp transport module.
[ 0.223422] RPC: Registered tcp transport module.
[ 0.223479] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.228574] Bus freq driver module loaded
[ 0.232419] workingset: timestamp_bits=30 max_order=17 bucket_order=0
[ 0.250413] NFS: Registering the id_resolver key type
[ 0.250548] Key type id_resolver registered
[ 0.250607] Key type id_legacy registered
[ 0.250681] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.252295] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.253435] fuse init (API version 7.26)
[ 0.270905] io scheduler noop registered
[ 0.270991] io scheduler deadline registered
[ 0.271488] io scheduler cfq registered (default)
[ 0.275747] backlight supply power not found, using dummy regulator
[ 0.279658] 21c8000.lcdif supply lcd not found, using dummy regulator
[ 0.280204] fbcvt: 640x480@60: CVT Name - .307M3
[ 0.391142] Console: switching to colour frame buffer device 80x30
[ 0.411857] mxsfb 21c8000.lcdif: initialized
[ 0.418239] imx-sdma 20ec000.sdma: loaded firmware 3.3
[ 0.431608] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 20, base_baud = 5000000) is a IMX
[ 1.079547] console [ttymxc0] enabled
[ 1.088800] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 63, base_baud = 5000000) is a IMX
[ 1.106226] 21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 64, base_baud = 5000000) is a IMX
[ 1.142942] loop: module loaded
[ 1.159735] random: fast init done
[ 1.170667] nand: device found, Manufacturer ID: 0xc2, Chip ID: 0xdc
[ 1.180967] nand: Macronix MX30LF4G28AC
[ 1.188638] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 112
[ 1.204850] gpmi-nand 1806000.gpmi-nand: mode:5 ,failed in set feature.
[ 1.216082] Bad block table found at page 262080, version 0x01
[ 1.226725] Bad block table found at page 262016, version 0x01
[ 1.237761] 5 ofpart partitions found on MTD device gpmi-nand
[ 1.247708] Creating 5 MTD partitions on "gpmi-nand":
[ 1.257062] 0x000000000000-0x000000080000 : "mx6ull-bcb"
[ 1.267630] 0x000000080000-0x000000200000 : "u-boot1"
[ 1.277768] 0x000000200000-0x000000380000 : "u-boot2"
[ 1.287753] 0x000000380000-0x000000400000 : "u-boot-env"
[ 1.297912] 0x000000400000-0x000020000000 : "ubi"
[ 1.319329] gpmi-nand 1806000.gpmi-nand: driver registered.
[ 1.333523] spi_imx 2008000.ecspi: probed
[ 1.342909] libphy: Fixed MDIO Bus: probed
[ 1.524392] pps pps0: new PPS source ptp0
[ 1.534517] libphy: fec_enet_mii_bus: probed
[ 1.545587] fec 20b4000.ethernet eth0: registered PHC device 0
[ 1.557269] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.567403] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 1.576594] usbcore: registered new interface driver usb-storage
[ 1.586557] usbcore: registered new interface driver usbserial
[ 1.596071] usbcore: registered new interface driver usbserial_generic
[ 1.606112] usbserial: USB Serial support registered for generic
[ 1.615556] usbcore: registered new interface driver ftdi_sio
[ 1.624681] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.638328] usbcore: registered new interface driver pl2303
[ 1.647233] usbserial: USB Serial support registered for pl2303
[ 1.658931] 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.679842] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 1.688472] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 1.723318] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 1.734669] hub 1-0:1.0: USB hub found
[ 1.742219] hub 1-0:1.0: 1 port detected
[ 1.752711] mousedev: PS/2 mouse device common for all mice
[ 1.769222] input: AD7879 Touchscreen as /devices/soc0/soc/2100000.aips-bus/21a4000.i2c/i2c-1/1-002c/input/input0
[ 1.789384] rtc-ds1307: probe of 0-0068 failed with error -5
[ 1.800767] snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc0
[ 1.817844] i2c /dev entries driver
[ 1.830154] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
[ 1.841631] sdhci: Secure Digital Host Controller Interface driver
[ 1.851942] sdhci: Copyright(c) Pierre Ossman
[ 1.860418] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.873333] sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
[ 1.943764] mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[ 2.023307] mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
[ 2.054900] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.065666] usbcore: registered new interface driver usbhid
[ 2.075656] usbhid: USB HID core driver
[ 2.092308] Netfilter messages via NETLINK v0.30.
[ 2.101567] nfnl_acct: registering with nfnetlink.
[ 2.111096] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
[ 2.124088] nf_tables: (c) 2007-2009 Patrick McHardy <kaber@trash.net>
[ 2.135603] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.146560] NET: Registered protocol family 10
[ 2.163526] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.173149] NET: Registered protocol family 17
[ 2.182050] Bridge firewalling registered
[ 2.190442] 8021q: 802.1Q VLAN Support v1.8
[ 2.198867] Key type dns_resolver registered
[ 2.213830] cpu cpu0: Registered imx6q-cpufreq
[ 2.245533] Registering SWP/SWPB emulation handler
[ 2.253356] registered taskstats version 1
[ 2.291118] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 2.298298] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 2.333291] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 2.342008] hub 2-0:1.0: USB hub found
[ 2.349911] hub 2-0:1.0: 1 port detected
[ 2.358043] imx_thermal 2000000.aips-bus:tempmon: Industrial CPU temperature grade - max:105C critical:105C passive:95C
[ 2.373490] ubi0: default fastmap pool size: 200
[ 2.380083] ubi0: default fastmap WL pool size: 100
[ 2.386741] ubi0: attaching mtd4
[ 2.730123] ubi0: attached by fastmap
[ 2.735593] ubi0: fastmap pool size: 200
[ 2.741137] ubi0: fastmap WL pool size: 100
[ 2.768702] ubi0: attached mtd4 (name "ubi", size 508 MiB)
[ 2.775943] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 2.784482] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 2.792900] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 2.801559] ubi0: good PEBs: 4060, bad PEBs: 4, corrupted PEBs: 0
[ 2.809329] ubi0: user volume: 4, internal volumes: 1, max. volumes count: 128
[ 2.819913] ubi0: max/mean erase counter: 3/1, WL threshold: 4096, image sequence number: 927536063
[ 2.832546] ubi0: available PEBs: 0, total reserved PEBs: 4060, PEBs reserved for bad PEB handling: 76
[ 2.845709] ubi0: background thread "ubi_bgt0d" started, PID 105
[ 2.857803] input: gpio-keys as /devices/soc0/gpio-keys/input/input1
[ 2.869132] snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:01 UTC (1)
[ 2.883959] soc_in: disabling
[ 2.890150] ALSA device list:
[ 2.895198] No soundcards found.
[ 2.903996] UBIFS (ubi0:3): background thread "ubifs_bgt0_3" started, PID 106
[ 3.001933] UBIFS (ubi0:3): recovery needed
[ 3.698285] UBIFS (ubi0:3): recovery completed
[ 3.707443] UBIFS (ubi0:3): UBIFS: mounted UBI device 0, volume 3, name "rootfs"
[ 3.723033] UBIFS (ubi0:3): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 3.741602] UBIFS (ubi0:3): FS size: 493936640 bytes (471 MiB, 3890 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
[ 3.761177] UBIFS (ubi0:3): reserved for root: 0 bytes (0 KiB)
[ 3.771538] UBIFS (ubi0:3): media format: w4/r0 (latest is w4/r0), UUID C0B5DD57-F297-492F-A286-C5C15BB31F0C, small LPT model
[ 3.798809] VFS: Mounted root (ubifs filesystem) on device 0:12.
[ 3.811344] devtmpfs: mounted
[ 3.818022] Freeing unused kernel memory: 1024K
[ 4.264772] random: crng init done
[ 4.779958] systemd[1]: System time before build time, advancing clock.
[ 5.050361] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS -ACL +XZ +LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 +IDN default-hierarchy=hybrid)
[ 5.102374] systemd[1]: Detected architecture arm.
[ 5.157436] systemd[1]: Set hostname to <colibri-imx6ull>.
[ 6.771822] systemd[1]: Listening on udev Kernel Socket.
[ 6.816352] systemd[1]: Listening on Network Service Netlink Socket.
[ 6.853643] systemd[1]: Reached target Swap.
[ 6.894217] systemd[1]: Listening on udev Control Socket.
[ 6.944266] systemd[1]: Created slice System Slice.
[ 6.985943] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 7.026706] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 8.794586] systemd-journald[126]: Received request to flush runtime journal from PID 1
[ 8.853384] systemd-journald[126]: File /var/log/journal/cd126bc4ae25423bb4caae935bc11e6c/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 11.081060] CAN device driver interface
[ 11.300760] mcp251x spi0.0: Cannot initialize MCP2515. Wrong wiring?
[ 11.360176] mcp251x spi0.0: Probe failed, err=19
[ 13.833898] using random self ethernet address
[ 13.840462] using random host ethernet address
[ 14.701071] usb0: HOST MAC 00:14:2d:ff:ff:fe
[ 14.730403] usb0: MAC 00:14:2d:ff:ff:ff
[ 15.249552] compat: loading out-of-tree module taints kernel.
[ 15.283592] Loading modules backported from Linux version v4.19.24-0-gf287634fe321
[ 15.295092] Backport generated by backports.git v5.0-rc6-1-8-gd3921c0f
[ 15.699883] Bluetooth: Core ver 2.22
[ 15.722327] NET: Registered protocol family 31
[ 15.728965] Bluetooth: HCI device and connection manager initialized
[ 15.750770] Bluetooth: HCI socket layer initialized
[ 15.760270] Bluetooth: L2CAP socket layer initialized
[ 15.767827] Bluetooth: SCO socket layer initialized
[ 15.897782] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 17.153382] Micrel KSZ8041 20b4000.ethernet-1:02: attached PHY driver [Micrel KSZ8041] (mii_bus:phy_addr=20b4000.ethernet-1:02, irq=-1)
[ 17.197738] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 19.284046] fec 20b4000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 19.291968] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
