Imx6ull device tree frame buffer
So my module does not seem to take account of what i set for lcdif in device tree
Once the kernel has booted i can issue fbset commands
fbset -g 800 480 800 480 32
fbset -t 42000 10 1 10 3 5 5
and the display is the correct size and set to the correct position on the physical lcd
Is there a way to set the frame buffer values in the device tree ?
You have to reset vidargs variable from U-Boot. Read more: Display Output, Resolution and Timings (Linux) | Toradex Developer Center
I cleared the vidargs flag
fw_setenv vidargs video
and hey presto it then used the settings from my device tree
