imx6ULL-colibri cannot connect internet
We have bought 10 pcs of imx6ull colibri modules and a Colibri Eval V3 board. As i try to install image to the modules one of them could not update the list in Easy Installer program. The rest 9 module is working well and properly installed with images from toradex Easy installer ver. 1.8
I installed 2.8b6 linux image using an SD card to the problematic module. Linux runs correctly but When i try to ping (8.8.8.8) google shows nothing back. But it is pinging my local addresses properly.
while the other 9 modules are connecting to internet properly over ethernet cable, one is only working over local network.
What could be the problem please help me
Could you please try to re-insert module? Some interfacec may not work correctly if module installed unproperly. If it will not help you can try to put module in a recovery mode and re-load Toradex Easy Installer.
