IMX6ULL Autorun takes ages to start
So once the unit is turned on i need to start my application automatically.
I have created a service
[Unit]
Description=myapp service, runs the program
After=multi-user.target
[Service]
Type=simple
ExecStart=/home/root/myapp
[Install]
WantedBy=multi-user.target
to run my app and i have done systemctl enable <service_name>.service which worked successfully.
Now when i turn on the module EVENTUALLY it executes
Here are some timings
(Time in seconds from power on)
10 : Kernel starts and splash screen is shown (expected operation)
25 : Screen goes blank - at this point i see
[ OK ] Started Login Service.
[ 14.987911] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.994753] Bluetooth: BNEP filters: protocol multicast
[ 15.036494] Bluetooth: BNEP socket layer initialized
[FAILED] Failed to start Load default USB gadget schema g1.schema.
30 : Screen displays a white screen with what looks like the login after (Do i need to disable this somehow in menuconfig ?)
37 : login appears on the console
109 : The application runs
Q. Do i need to get it to auto login ?
Q. Why does it take so long to run
Dear @adrian,
For the error, “Failed to start Load default USB gadget schema g1.schema” , there is a fix already in the commuity mentioned. Not sure if it will work for BSP 3, but you can try to check that. Linux gadget on iMX7 - Technical Support - Toradex Community
I have a couple of questions:
  • Does the module vootup to desktop if you don’t enable in the service?
  • What exact reference image is your image based upon?
Furthermore, to benchmark systemd there is systemd-analyze which might be helpful:
Normally,there should not be any issue, so could you please check your service again?
Janani
The module boots up to the console (No GUI desktop)
I expect my service is only run once everything has completed installing.
I wonder if there is something i can change in my service to make it start straight away as soon a s login appears
Hello @adrian,
How long does it take to boot up to the desktop (without your service)? If the boot -up is faster and as usual, I wonder if it could be something with your app service?
Janani
If i login via the terminal the app starts straight away.
Is it waiting for a login timeout to expire ? then starting without any external login ?
I dont quite understand what you mean by “login via terminal”. Could you please be more specific?
login via terminal .. i have a serial port connected to the terminal output.
The unit boots up and then ends at
imx6ull login
As soon as i type ROOT the app starts
I now wonder if without typing anything, the login times out and then my program runs
So the line in the service i was missing is
Before=getty.target
so the full service looks like this
[Unit]
Before=getty.target
[Service]
Type=simple
[Install]
Hello @adrian ,
So, this line added to your application now fixes the issue?
Janani
Yes, as soon as the splash screen clears my service runs immediately and my app starts
Hello @adrian ,
That’s perfect! Thank you for your reply
