Trying to get 2x parallel RGB outputs from the second display interface channel on IPU1 on the imx6dl. The first lcd channel works as expected (no issues). Have had no success displaying an image on lcd2 channel. please advise.
I have performed the following steps but for some reason the sodimm_45 pixelclk cannot be observed on a scope.
- Patched the kernel driver mxc_lcdif.c to include support for a second LCD
static struct mxc_dispdrv_driver lcdif_drv = { {
.name = DISPDRV_LCD,
.init = lcdif_init,
.deinit = lcdif_deinit,
.name = DISPDRV_LCD2,
.init = lcdif_init,
Revised imx6qdl-colibri.dtsi as shown with a limited set of pins for now for testing. On a scope, i observe sync pulses at 60hz refresh rate as expected.
lcd2: lcd@1 {
compatible = "fsl,lcd";
ipu_id = <0>;
disp_id = <1>;
default_ifmt = "RGB24";
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_ipu1_lcdif_ch2>;
status = "disabled";
pinctrl_ipu1_lcdif_ch2: ipu1lcdifgrp2 {
fsl,pins = <
MX6QDL_PAD_EIM_A16__IPU1_DI1_DISP_CLK 0xa1 //pixel clock
MX6QDL_PAD_EIM_DA11__IPU1_DI1_PIN02 0xa1 //HSYNC
MX6QDL_PAD_EIM_DA12__IPU1_DI1_PIN03 0xa1 //VSYNC
MX6QDL_PAD_EIM_DA10__IPU1_DI1_PIN15 0xa1 //ENABLE
MX6QDL_PAD_EIM_DA9__IPU1_DISP1_DATA00 0xa1 //BLUE00
My custom .dts overlay activates the framebuffers as follows:-
&mxcfb1 {
compatible = “fsl,mxc_sdc_fb”;
disp_dev = “lcd”;
interface_pix_fmt = “RGB24”;
mode_str =“Aspire”;
default_bpp = <32>;
int_clk = <0>;
late_init = <0>;
status = “okay”;
&mxcfb2 {
disp_dev = “lcd2”;
mode_str =“Aspire”;
default_bpp = <32>;
int_clk = <0>;
late_init = <0>;
status = “okay”;
