Imx6 update failed
Hi
I have tried to update two apalis imx6 modules to the latest image. Now when i boot i get nothing. not even output on serial.
I have tried to recover them. i get the serial pop up and it says to insert sd and then to power cycle the board to continue setup. When doing this i get blank screens again.
What am i doing wrong?
What OS are you using? Windows CE?
Can you try to use our Easy Installer to recover those modules?
http://developer.toradex.com/software/toradex-easy-installer
Thanks. I didnt try this method.
