i am following the steps mentioned in selep by step guide of colibri iMX6 and iris with linux (using torizon) and facing problem in Step 5 of Build and Run your First ApplicationBuild and Run your First Application
it show error standard_init_linux.go:211: exec user process caused “exec format error”:
Greetings @Puneet_Kumar_Pal,
To properly build arm32 containers on your development PC you’ll need to install some emulation binaries. The following document describes how to do that: Configure Build Environment for Torizon Containers | Toradex Developer Center
I apologize as this point isn’t made very clearly in the getting started I’ll work to make sure this is pointed out more clearly in the future.
Dear @Puneet_Kumar_Pal ,
Thank you for your input. The instructions on the page were updated.
Kind Regards,
Denis Shimizu
