I’ve been building a custom Linux image using Yocto with a custom device tree source.
I have enabled all the PWMs by setting the status to ‘okay’, but only 2 PWMs are availalble in user space under /sys/class/pwm.
The device tree source looks like this:
/dts-v1/;
#include <dt-bindings/input/input.h>
#include <dt-bindings/interrupt-controller/irq.h>
#include "imx6dl.dtsi"
#include "imx6qdl-colibri.dtsi"
model = "Toradex Colibri iMX6DL/S on Colibri Evaluation Board V3";
compatible = "toradex,colibri_imx6dl-eval", "toradex,colibri_imx6dl", "fsl,imx6dl";
aliases {
/* the following, together with kernel patches, forces a fixed assignment
between device id and usdhc controller */
/* i.e. the eMMC on usdhc3 will be /dev/mmcblk0 */
mmc0 = &usdhc3; /* eMMC */
mmc1 = &usdhc1; /* MMC 4bit slot */
extcon_usbc_det: usbc_det {
compatible = "linux,extcon-usb-gpio";
debounce = <25>;
id-gpio = <&gpio7 12 GPIO_ACTIVE_HIGH>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_usbc_det_1>;
gpio-keys {
compatible = "gpio-keys";
pinctrl-0 = <&pinctrl_gpio_keys>;
wakeup {
label = "Wake-Up";
gpios = <&gpio2 22 GPIO_ACTIVE_HIGH>;
linux,code = <KEY_WAKEUP>;
debounce-interval = <10>;
gpio-key,wakeup;
regulators {
reg_usb_host_vbus: usb_host_vbus {
&iomuxc {
pinctrl-0 = <
&pinctrl_gpio_unit1
&pinctrl_pwm_unit1
gpio {
pinctrl_gpio_unit1: gpio-unit1 {
fsl,pins = <
/* Pins for the GPIO IN */
MX6QDL_PAD_EIM_D17__GPIO3_IO17 PAD_CTRL_HYS_PU /* SODIMM 96 */
/* EN */
MX6QDL_PAD_SD2_DAT0__GPIO1_IO15 PAD_CTRL_HYS_PU /* SODIMM 98 */
/* Pins for the STATUS LEDS */
MX6QDL_PAD_NANDF_D4__GPIO2_IO04 PAD_CTRL_HYS_PU /* SODIMM 102 */
MX6QDL_PAD_SD4_DAT0__GPIO2_IO08 PAD_CTRL_HYS_PU /* SODIMM 104 */
/* Pins for the HW WATCHDOG */
MX6QDL_PAD_GPIO_9__GPIO1_IO09 PAD_CTRL_HYS_PU /* SODIMM 28 */
pwm {
pinctrl_pwm_unit1: pwm-unit1 {
fsl,pins = <
/* PWM */
MX6QDL_PAD_SD4_DAT1__PWM3_OUT 0x1b0b1 /* SODIMM 59 */
&pwm1 {
&pwm2 {
/* PWM */
&pwm3 {
&pwm4 {
/* UART for serial interface with module */
&uart1 {
/* UART for RS485 communication */
&uart2 {
/* USB */
&usbh1 {
/* USB-OTG for debugging purposes */
&usbotg {
extcon = <&extcon_usbc_det>, <&extcon_usbc_det>;
/* MMC */
&usdhc1 {
&weim {
fsl,weim-cs-gpr = <&gpr>;
/* weim memory map: 32MB on CS0, 32MB on CS1, 32MB on CS2, 32MB on CS3 */
ranges = <0 0 0x08000000 0x02000000
1 0 0x0a000000 0x02000000
2 0 0x0c000000 0x02000000
3 0 0x0e000000 0x02000000>;
/* SRAM on CS0 */
sram@0,0 {
compatible = "cypress,cy7c1019dv33-10zsxi, mtd-ram";
reg = <0 0 0x00010000>;
#address-cells = <1>;
#size-cells = <1>;
bank-width = <2>;
fsl,weim-cs-timing = <0x00010081 0x00000000 0x04000000
0x00000000 0x04000040 0x00000000>;
/* SRAM on CS1 */
sram@1,0 {
reg = <1 0 0x00010000>;
#size-cells = <1>;
bank-width = <2>;
This is the result of an ls command on /sys/class/pwm:
root@colibri-imx6:/sys/class/pwm# ls -l
lrwxrwxrwx 1 root root 0 Mar 6 14:43 pwmchip0 -> ../../devices/soc0/soc/2000000.aips-bus/2084000.pwm/pwm/pwmchip0
lrwxrwxrwx 1 root root 0 Mar 6 14:43 pwmchip1 -> ../../devices/soc0/soc/2000000.aips-bus/208c000.pwm/pwm/pwmchip1
Does anyone know why only 2 PWMs are available and visible in user space instead of all 4 and how I can fix this?
Thanks in advance!
