We would like to know if ít’s possible to create a second partition with the following characteristics:
- Data persistent after firmware update (run setupdate; run update)
- possibility to flash from this partition instead of a seperate sd/usb
Also we like you to know how to archieve this and what needs to be changed in the yocto build environment
