I can wake Linux up using UART by enabling its wakeup capability:
$ echo enabled > /sys/class/tty/ttymxc0/power/wakeup
I have put Linux into sleep using the following command:
$ echo mem > /sys/power/state
then sending a character over UART when the Linux is in sleep to wake it up… This scenario works well.
I want to do the same with CAN, so I enable its wakeup capability:
$ echo enabled > /sys/class/net/can0/device/power/wakeup
Then put Linux into sleep. It shows that Linux goes into sleep, but it immediately wakes up. I want Linux to be woken up upon the reception of a frame over CAN, just like the UART scenario
Hardware: apalis imx6D ixora v1.2
OS: Linux 5.4.91-33088-g8c05b31a44c3
Question: What could be the problem? How can I do that?
Thanks in advance
