the output video on HDMI and LVDS and filesink is blurred.
I use a standard analogue NTSC pattern generator as ADA input video source.
When I saw that the video output on screen is blurred I recorded the raw video and I play it with YUVPlayer (you download it from here) and I also could see the blurred problem on recorded file.
I don’t have experience about the iMX6 Input filter and the Line Dobler but the issue seems to be related to interlacing and cross-chrominance artifacts. The video decoder used in the Analogue camera adapter provides a multiline adaptive comb filter to reduce these effects. You should have look at the datasheet of Adv7280.
