Hello
I am trying to boot my board from micro sd card, I have created an bootable micro sd card and plugged it in my board, and run the commands
run setupdate
run update
end it shows me this TIMOUT error, what am i doing wrong ?
Thanks for help.
hi
Which version of the software are you using?
Could you go to U-Boot and reset the environment variables to default as described here and then reboot the module?
Hello
I solved the issue
I just tried 3-4 times again and it worked…
Thanks for reply
Perfect, that it works. Thanks for the feedback.
