Hello
I am trying to make an application with Qt to read CAN BUS frames.
I am able to capture CAN packages with High performance, low power Embedded Computing Systems | Toradex Developer Center these configurations on the terminal.
When I tried it with my application it continuously dumps on the screen only
“(Invalid)”
here is my simple CAN codes on Qt and this is the link that I followed Using SocketCAN Plugin | Qt Serial Bus 5.11
Thanks for help, I am stuck on it !
The question is rather Qt specific and maybe better placed in a Qt forum.
Taken from this examples it seems that you should wait until a frame is available before reading it?
while (m_canDevice->framesAvailable()) {
const QCanBusFrame frame = m_canDevice->readFrame();
Also consider checking the return value of connectDevice() and print ->errorString() if it fails… Implementing proper error handling is good practise and should be the first thing to check if code fails.
