I am currently working on integrating the IMX219 camera sensor with the Verdin i.MX8MP board. I have added the required device tree configuration as shown below.
DTS Configurations:
&i2c3 {
imx219: imx219@10 {
compatible = "sony,imx219";
reg = <0x10>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_gpio_hog3>;
clock-names = "xclk";
clocks = <&clk IMX8MP_CLK_IPP_DO_CLKO2>;
assigned-clocks = <&clk IMX8MP_CLK_IPP_DO_CLKO2>;
assigned-clock-parents = <&clk IMX8MP_CLK_24M>;
assigned-clock-rates = <24000000>;
mclk = <24000000>;
mclk_source = <0>;
csi_id = <1>;
mipi-csi;
reset-gpios = <&gpio1 1 GPIO_ACTIVE_HIGH>;
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
imx219_to_mipi_csi2: endpoint {
remote-endpoint = <&mipi_csi_1_in>;
bus-type = <4>;
clock-lanes = <0>;
data-lanes = <1 2>;
link-frequencies = /bits/ 64 <456000000>;
&cameradev {
&mipi_csi_1 {
#size-cells = <0>;
port@0 {
reg = <0>;
mipi_csi_1_in: endpoint {
remote-endpoint = <&imx219_to_mipi_csi2>;
data-lanes = <1 2>;
csis-hs-settle = <13>;
csis-clk-settle = <2>;
csis-wclk;
&isp_1 {
&dewarp {
Issue: Although the camera sensor sub-device and MIPI-CSI node are created, the media link is not established. Below are the relevant kernel logs:
[ 9.306696] mxc-md 32c00000.bus:camera: deferring csi device registration
[ 9.365638] mxc-mipi-csi2-sam 32e50000.csi: supply mipi-phy not found, using dummy regulator
[ 9.457142] mxc-mipi-csi2-sam 32e50000.csi: lanes: 1, hs_settle: 0, clk_settle: 0, wclk: 0, freq: 266000000
[ 9.458979] mx8-img-md: Registered sensor subdevice: imx219 2-0010 (1)
[ 9.458995] mxc-md 32c00000.bus:camera: mxc_md_create_links
[ 9.524001] mxc-mipi-csi2.1: mipi_csis_imx8mp_phy_reset, No remote pad found!
media-ctl -p output:
Media device information
driver mxc-md
model FSL Capture Media Device
serial
bus info platform:32c00000.bus:camera
hw revision 0x0
driver version 6.6.74
Device topology
- entity 1: mxc-mipi-csi2.1 (8 pads, 0 link)
type Node subtype V4L flags 0
device node name /dev/v4l-subdev0
pad0: Sink
pad1: Sink
pad2: Sink
pad3: Sink
pad4: Source
pad5: Source
pad6: Source
pad7: Source
- entity 10: imx219 2-0010 (1 pad, 0 link, 0 routes)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev1
pad0: Source
[stream:0 fmt:SRGGB10_1X10/3280x2464 field:none colorspace:raw xfer:none quantization:full-range
crop.bounds:(8,8)/3280x2464
crop:(8,8)/3280x2464]
It appears the media links between the IMX219 sensor and MIPI CSI interface are not being established. Could you please help me identify what might be missing or incorrectly configured?
Hardik
