Dear Sir,
I`m switching from apalis t30 to apalis IMX 6 and can not configure LVDS display to work properly. I have a single channel display configured for T30 as below:
gpio-216 (LVDS: Single/Dual Ch) HIGH SINGLE CHANNEL
gpio-219 (LVDS: 18/24 Bit Mode) LOW 24 bit (8 bit per colour) mode
gpio-220 (LVDS: Output Enable ) HIGH LVDS output enabled
gpio-221 (LVDS: Power Down ) HIGH Normal operation
gpio-222 (LVDS: Clock Polarity) HIGH Rising edge (preferred setting for Apalis T30)
gpio-223 (LVDS: Colour Mapping) LOW Common 24 bit colour mode (VESA format, Figure 11)
gpio-225 (LVDS: Swing Mode ) HIGH 350mV (standard LVDS value)
gpio-226 (LVDS: DDRclk Disable) HIGH DDR disabled (preferred setting for Apalis T30)
video=tegrafb0:1024x768R-16@60
and display works correctly under apalis T30. I’m trying to configure this display under apalis IMX 6 following this manual: Display Output, Resolution and Timings (Linux) | Toradex Developer Center , by setting kernel command line as below
fw_setenv vidargs video=mxcfb0:dev=ldb,bpp=24,1024x768R-16@60,if=RGB24 ldb=sin0
but display doesn’t work (Only penguin appear for a second). What I have noticed, that even running simple command: video=mxcfb0:dev=ldb,640x480M@60 does not change resolution under X server (checked with vnc viewer)
My system is
uname -a
Linux apalis-imx6 4.1.44-2.7.4+gb1555bf #1 SMP Wed Oct 4 22:39:51 UTC 2017 armv7l GNU/Linux
The Angstrom Distribution \n \l
Angstrom v2016.12 - Kernel
Apalis-iMX6_LXDE-Image 2.7b4 20171004
