This KB describes how to use Segger J-Link debug probe to JTAG debugging Cortex-M firmware on some Toradex SoMs, using VS Code.
Searching in google I found this wiki from Segger that seems very clear and effective (IMHO).
It describes how to set launch.json
with the elements:
- jlinkscript
- svdFile
For iMX8M-Plus both of them are included in the IAR and SEGGER tool patch for i.MX8M Plus devices available on NXP website.
I took inspiration from this Segger woki and I decided to specify arm_toolchain_dir
in settings.json
"arm_toolchain_dir": "C:\\Program Files (x86)\\Arm GNU Toolchain arm-none-eabi\\11.3 rel1"
and in this way I can use the path both in:
tasks.json
"env": { "ARMGCC_DIR": "${config:arm_toolchain_dir}" }
launch.json
"armToolchainPath": "${config:arm_toolchain_dir}/bin"
without the need to specify the path twice (as in the original Toradex KB).
I did it for Windows 10, but I see that in Segger wiki there is the Ubuntu section too (not tried).
