Hey everyone! I wanted to ask if anyone here has tried using Pyarmor to obfuscate their python code and then deploy it to their board using the VSCode extension. I am able to obfuscate the code and run it locally with pyarmor, but once I try putting it on the board, I get the following error:
machinepulse-1 | from .pyarmor_runtime import __pyarmor__
machinepulse-1 | ImportError: /home/torizon/app/src/distributed_python/pyarmor_runtime_000000/pyarmor_runtime.so: cannot open shared object file: No such file or directory
machinepulse-1 | Traceback (most recent call last):
machinepulse-1 | File "/home/torizon/app/src/distributed_python/main.py", line 2, in <module>
machinepulse-1 | from pyarmor_runtime_000000 import __pyarmor__
machinepulse-1 | File "/home/torizon/app/src/distributed_python/pyarmor_runtime_000000/__init__.py", line 2, in <module>
When I go into my docker container to look at the files, I can clearly see this file is there and in the correct place. For further context, here is my dockerfile:
# ARGUMENTS --------------------------------------------------------------------
## Board architecture
ARG IMAGE_ARCH=
## Base container version
ARG BASE_VERSION=3.3.0-bookworm
## Directory of the application inside container
ARG APP_ROOT=
FROM --platform=linux/${IMAGE_ARCH} \
torizon/debian:${BASE_VERSION} AS Deploy
ARG IMAGE_ARCH
ARG APP_ROOT
# Metadata label
LABEL org.opencontainers.image.description="test description."
# Install system-wide required packages
RUN apt-get -q -y update && \
apt-get -q -y install \
python3-minimal \
python3-pip \
python3-dbus \
python3-venv \
tzdata \
network-manager \
systemd \
dbus \
build-essential \
libsqlcipher-dev \
python3-dev \
&& apt-get clean && apt-get autoremove && \
rm -rf /var/lib/apt/lists/*
# Additional installations for dependencies like msodbcsql
RUN apt-get update \
&& apt-get install -y --no-install-recommends \
gnupg \
g++ \
unixodbc-dev \
curl \
&& curl -fsSL https://packages.microsoft.com/keys/microsoft.asc | gpg --dearmor -o /usr/share/keyrings/microsoft-prod.gpg \
&& curl https://packages.microsoft.com/config/debian/12/prod.list > /etc/apt/sources.list.d/mssql-release.list \
&& apt-get update \
&& ACCEPT_EULA=Y apt-get install -y --no-install-recommends msodbcsql18 \
&& apt-get clean \
&& rm -rf /var/lib/apt/lists/*
# Create a Python virtual environment
RUN python3 -m venv ${APP_ROOT}/.venv --system-site-packages
# Copy requirements file
COPY requirements-release.txt /requirements-release.txt
# Activate virtualenv and install pip packages, including PyArmor
# Install pip packages on venv with force flag to bypass system environment warning
RUN . ${APP_ROOT}/.venv/bin/activate && \
pip3 install --upgrade pip && \
pip3 install --break-system-packages pyarmor && \
pip3 install -r requirements-release.txt && \
rm requirements-release.txt
# Copy the entrypoint script and make it executable
COPY entrypoint.sh /usr/local/bin/entrypoint.sh
RUN chmod +x /usr/local/bin/entrypoint.sh
# Copy the application source code to the container
COPY ./src ${APP_ROOT}/src
# Set the working directory
WORKDIR ${APP_ROOT}
# Set the environment variable
ENV APP_ROOT=${APP_ROOT}
# Set the entrypoint
ENTRYPOINT ["/usr/local/bin/entrypoint.sh"]
# Activate the virtual environment and run the main script
CMD . ${APP_ROOT}/.venv/bin/activate && python3 src/distributed_python/main.py --no-sandbox
The dockerfile calls main.py, which it can clearly find. Here’s the beginning of main.py:
__pyarmor__(__name__, __file__, b'PY000000\x00\x03\n\x00o\r\r\n\x80\x00\x01\x00\x08\x00\x00\x00\x04\x00\x00\x00@\x00\x00\x00x\x8c\x00\x00\x12\t\x04\x00B0-\xf9j\xa8I9G\x1cv\xafY0~\x01\x00\x00\x00\x00\x00\x00\x00\x00g\xc4M\x95+\xf1\x9c\x9b\xd7\x92\x92
pyarmor_runtime_00000 contains an init.py which is solely the following:
# Pyarmor 8.5.12 (trial), 000000, 2024-10-16T12:52:44.700199
Anyone have any suggestions to solve this import error? Thank you!
