Hello Flavio,
Thank you for your question!
Based on your requirements, you want to create a .wic image for an internal eMMC, with a reserved ext4 partition that should not be overwritten when using the U-Boot gzwrite command to flash the image.
Here are some key points and workflow recommendations for Toradex modules:
Partition Scheme on Toradex Modules
It is possible to create a custom partition scheme like the one you described:
/dev/mmcblk0p1: FAT boot partition (for bootloader/kernel)
/dev/mmcblk0p2: ext4 reserved partition (keep intact)
/dev/mmcblk0p3: ext4 rootfs (main Linux system)
Reference: Booting from eMMC on Apalis/Colibri modules
About WIC Images
A .wic image typically represents the whole disk layout, so flashing it will overwrite all partitions on your eMMC unless you use a tool or method that flashes only a specific partition.
Using gzwrite in U-Boot
The U-Boot gzwrite command (often available in newer U-Boot versions) is designed to write compressed images directly to a block device. When used to flash a full disk image, it will overwrite the entire device, including your reserved partition.
To preserve your reserved partition (/dev/mmcblk0p2), consider these options:
Option 1: Flash Only Specific Partitions
- Split your images (for p1 and p3) and write them individually to their corresponding partitions using raw device writes in U-Boot or Linux, leaving p2 untouched. You can create a separate image for the boot and rootfs partitions.
- This requires your install process (or U-Boot script) to address each partition by offset and size.
- U-Boot commands for individual partitions may depend on the availability of commands like
mmc write.
Option 2: Custom Installation Process
- Use the Toradex Easy Installer, which can be scripted to preserve certain partitions if you customize its manifest accordingly.
Option 3: Two-Stage Flashing
- Flash the whole image (with the reserved partition unformatted), then in a secondary process, restore or re-create the reserved partition’s contents if needed.
Summary Recommendation
If your requirement is to never overwrite /dev/mmcblk0p2, it is safest to avoid full-disk images with .wic for gzwrite and instead update partitions individually.
- If you must use
gzwrite with a .wic image, be aware this will overwrite all partitions.
- For production, using a scripting approach (with part-by-part updates) or the Easy Installer with a custom script will give you the fine control necessary.
Learn more here:
If you need assistance on scripting individual partition updates or customizing the Toradex Easy Installer, please let me know!
