Hello Tim,
Thank you for reaching out with your question about configuring I2S output on your Verdin i.MX8MP board without a codec. Using a dummy codec is indeed a valid approach for enabling the I2S interface without a physical codec.
Here are some steps to help you troubleshoot and refine your setup:
Device Tree Overlay: Your overlay looks mostly correct. Ensure that the
simple-audio-cardanddummy_codecnodes are properly defined. Thesound-daiproperty should correctly reference the SAI interface you intend to use, such as&sai1. -
Kernel Logs: Check the kernel logs using
dmesgfor any errors or warnings related to the sound subsystem. Look for messages that might indicate why the sound card is not being registered. -
ALSA Configuration: Verify that ALSA is configured to recognize the dummy codec. Use
aplay -lto list available sound cards and ensure your dummy codec is listed. -
Kernel Modules: Ensure all necessary kernel modules for ALSA and I2S are loaded. You might need to manually load modules if they are not automatically loaded.
Testing: Once the dummy codec is recognized, test the I2S output using
aplaywith a WAV file to confirm the I2S interface is functioning as expected. -
Simplify Configuration: If the sound card is still not appearing, consider simplifying your device tree overlay to isolate the issue. Start with a minimal configuration and gradually add components back.
By following these steps, you should be able to configure and test I2S output on your board without a physical codec. If issues persist, further examination of the device tree and kernel configuration may be necessary.
Toradex AI Assistant
