I follow How to use I²C on Torizon OS | Toradex Developer Center
I want to install i2c-tools and I have dockerfile
ARG BASE_NAME=arm32v7-debian-qt5-wayland
FROM torizon/$BASE_NAME:buster
SHELL ["/bin/bash", "-c"]
RUN apt-get -y update && apt-get install -y
RUN apt-get install -y i2c-tools
RUN apt-get install nano -y ...
I run
docker build -t qt5-dev -f Dockerfile .
and I got
Setting up udev (241-7~deb10u7) ...
The group `input' already exists and is not a system group. Exiting.
dpkg: error processing package udev (--configure):
installed udev package post-installation script subprocess returned error exit status 1
Setting up libgdbm-compat4:armhf (1.18.1-4) ...
Setting up libperl5.28:armhf (5.28.1-6+deb10u1) ...
Setting up perl (5.28.1-6+deb10u1) ...
dpkg: dependency problems prevent configuration of i2c-tools:
i2c-tools depends on udev; however:
Package udev is not configured yet.
dpkg: error processing package i2c-tools (--configure):
dependency problems - leaving unconfigured
Processing triggers for libc-bin (2.28-10) ...
Errors were encountered while processing:
udev
i2c-tools
E: Sub-process /usr/bin/dpkg returned an error code (1)
The command '/bin/bash -c apt-get install -y i2c-tools' returned a non-zero code: 100
container from Dockerfile
FROM --platform=linux/arm torizon/debian:2-bullseye
built successfully
How to install i2c-tools into a container on the arm32v7-debian-qt5-wayland ?
