Hello all,
I tried in different way to write on EEprom.
The EEPROM has 16 Byte addressing (24LC64)
It gave me always the same results, no error, ff when I read.
I used the i2c-tools, a simple SysFS write read and a c program. I saw the generic driver too(when I enabled it I check that was used with i2c-detect -y 1), but so far nothing works at expected.
No error, but when I read it I always got 0xff.
root@b2qt-colibri-imx7-emmc:~# date | strace eeprog -f -16 -w 0 /dev/i2c-1 0x50
execve("/usr/sbin/eeprog", ["eeprog", "-f", "-16", "-w", "0", "/dev/i2c-1", "0x50"], 0x7eddfd38 /* 17 vars */) = 0
brk(NULL) = 0xa78000
uname({sysname="Linux", nodename="b2qt-colibri-imx7-emmc", ...}) = 0
mmap2(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x76f73000
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/etc/ld.so.cache", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=24257, ...}) = 0
mmap2(NULL, 24257, PROT_READ, MAP_PRIVATE, 3, 0) = 0x76f6d000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/libi2c.so.0", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\324\6\0\0004\0\0\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=5312, ...}) = 0
mmap2(NULL, 69640, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x76f3c000
mprotect(0x76f3d000, 61440, PROT_NONE) = 0
mmap2(0x76f4c000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0) = 0x76f4c000
close(3) = 0
openat(AT_FDCWD, "/lib/libc.so.6", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\271u\1\0004\0\0\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=923264, ...}) = 0
mmap2(NULL, 992036, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x76e49000
mprotect(0x76f26000, 65536, PROT_NONE) = 0
mmap2(0x76f36000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xdd000) = 0x76f36000
mmap2(0x76f39000, 8996, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x76f39000
close(3) = 0
set_tls(0x76f73ff0) = 0
mprotect(0x76f36000, 8192, PROT_READ) = 0
mprotect(0x76f4c000, 4096, PROT_READ) = 0
mprotect(0x4bb000, 4096, PROT_READ) = 0
mprotect(0x76f75000, 4096, PROT_READ) = 0
munmap(0x76f6d000, 24257) = 0
write(2, "eeprog 0.7.5, a 24Cxx EEPROM rea"..., 43eeprog 0.7.5, a 24Cxx EEPROM reader/writer
) = 43
write(2, "Copyright (c) 2003 by Stefano Ba"..., 61Copyright (c) 2003 by Stefano Barbato - All rights reserved.
) = 61
write(2, " Bus: /dev/i2c-1, Address: 0x50"..., 46 Bus: /dev/i2c-1, Address: 0x50, Mode: 16bit
) = 46
openat(AT_FDCWD, "/dev/i2c-1", O_RDWR) = 3
ioctl(3, _IOC(0, 0x7, 0x5, 0), 0x7ecb0ae8) = 0
ioctl(3, _IOC(0, 0x7, 0x3, 0), 0x50) = 0
write(2, " Writing stdin starting at addr"..., 40 Writing stdin starting at address 0x0
) = 40
fstat64(0, {st_mode=S_IFIFO|0600, st_size=0, ...}) = 0
brk(0xa99000) = 0xa99000
read(0, "Thu Feb 20 15:53:14 UTC 2020\n", 4096) = 29
write(2, ".", 1.) = 1
ioctl(3, _IOC(0, 0x7, 0x20, 0), 0x7ecb0a80) = 0
nanosleep({tv_sec=0, tv_nsec=5000000}, NULL) = 0
read(0, "", 4096) = 0
write(2, "\n\n", 2
) = 2
close(3) = 0
exit_group(0) = ?
+++ exited with 0 +++
This is an example, but I tried with the c program in attachment an when I read I have only garbage.
