community.docx (130.5 KB)
I reported my issue in the attached document.
Greetings @Innostech,
First of all are you using our TorizonCore OS? Or are you using our reference images?
Secondly, in the images you provided you can see the devices found in i2cdetect are denoted with a UU. This means that the device is being used/controlled by some kernel driver. I imagine this is why you get that error when trying to access the device with i2c utilities. Since the device is being used by a kernel driver it’s “busy” in order to prevent conflicting access/usage of the device.
