getting issue while board sending first message on the can bus, the bus is going in off state but if another node or host pc initiate the can communication first then there is no any issue while communication
Please let us know details about the hardware and software(OS) you are using in order to understand and support you.
Ritesh Kumar
using i.mx8qm mek with Linux and android 9 versions for adas project
Hi Aksh,
Please note this community is meant only for Toradex module and BSP we support.
I would request you to kindly post your query to right forum to get better response as we do not have experience with the board and BSP you are working with.
Ritesh kumar
