hi i am using i.mx 8 qm facing issue while can communication if i.mx 8qm want to send the first message the bus is going in off state
but if another node or host pc sends the first message that time there is no issue all communication working fine
Are you using Toradex product? This community is for Toradex module and BSP which we support. For any other board we may not be having correct information and will not help you resolving your queries.
Still you can check below article if it helps
Ritesh Kumar
