I’m trying to make the 10.1" HannStar HSD101PWW1 work on multi touch LVDS adapter (1280x800 resolution). The image do not fill the entire LCD area (see the image below). The display link: 10.1 HannStar HSD101PWW1 LCD Screen Display With Mounting Hole [HSD101PWW1-A] - US $40.00 : HAOYU Electronics : Make Engineers Job Easier
My .dtsi configuration:
timing_wsvga: 1280x800 {
clock-frequency = <48000000>;
hactive = <1280>;
vactive = <800>;
hback-porch = <104>;
hfront-porch = <43>;
vback-porch = <24>;
vfront-porch = <20>;
hsync-len = <5>;
vsync-len = <5>;
de-active = <1>;
hsync-active = <0>;
vsync-active = <0>;
pixelclk-active = <0>;
I also configured the u-boot env:
setenv vidargs 'video=dcufb:pixclockpol:0,vsync:0,hsync:0,1280x800-16@60'
The xrandr output:
colibri-imx7 login: root
root@colibri-imx7:~# xrandr
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 1024 x 768, current 1024 x 768, maximum 1024 x 768
default connected 1024x768+0+0 0mm x 0mm
1024x768 60.00*
I’m not sure if these configurations are valid or not. Why xrandr do not show 1280x800? Which files should I configure?
I’ve read the articles on the following links but I could not manage to work.
Best regards
