Docker Compose Path Issues with VS Code and Torizon Extension
This is a common environment variable issue when VS Code can’t access the same PATH that your terminal session has. Here are the solutions:
For Windows with WSL2
Launch VS Code from WSL2 terminal:
- Open your WSL2 terminal (Ubuntu/Debian)
- Navigate to your project directory
- Run:
code . - This ensures VS Code inherits the correct PATH from your WSL2 environment(1)
Verify Docker context:
- In VS Code, check that your Docker context is set to WSL2
- The Torizon extension should detect your WSL2 Docker installation
For Linux Development Environment
Check VS Code launch method:
- Always launch VS Code from the terminal where docker-compose works
- Run:
which docker-composeto verify the path - Then launch:
code .from the same terminal
Environment variable inheritance:
- VS Code needs to inherit the same environment variables as your terminal
- Launching from the terminal ensures proper PATH inheritance
Torizon Extension Requirements
The Torizon VS Code Extension requires docker-compose for multi-container application development(2). The extension uses Docker Compose to define and run multi-container applications(3).
Verification Steps
Test in terminal:
docker-compose --version which docker-compose -
Launch VS Code correctly:
cd /path/to/your/torizon/project code . -
Check VS Code terminal:
- Open VS Code’s integrated terminal
- Run
docker-compose --versionto verify it’s accessible
The key is ensuring VS Code inherits the same environment as your working terminal session where docker-compose is accessible(1).
