I followed the instructions for installing and running everything on the target board all the way through building and running hello_world from the command line and in Eclipse. Then I compiled the rpmsg ping pong example and tried to follow the instructions to use setenv to set m4boot and make it run automatically (I have the elf file on an sd card which is inserted on the carrier board).
From that point forward it not only says that it can’t find the rpmsg ping pong elf file but it no longer boots Linux and just gives me a bootp message until it times out. It does this whether I leave the sd card inserted or not. I have no clue how to restore it to work again, nor how to get an m4boot working from the instructions that are very unclear.
Here is my printenv output:
printenv
arch=arm
baudrate=115200
board=colibri_imx7
board_name=colibri_imx7
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}extlinux/extlinux.conf
boot_file=zImage
boot_net_usb_start=usb start
boot_prefixes=/ /boot/
boot_script_dhcp=boot.scr.uimg
boot_scripts=boot.scr.uimg boot.scr
boot_targets=mmc1 usb0 dhcp
bootargs=ip=off root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait console=tty1 console=ttymxc0,115200n8 consoleblank=0 video=mxsfb:640x480M-16@60
bootcmd=run emmcboot ; echo ; echo emmcboot failed ; setenv fdtfile ${soc}-colibri-emmc-${fdt_board}.dtb && run distro_bootcmd;
bootcmd_dhcp=if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;
bootcmd_mmc1=setenv devnum 1; run mmc_boot
bootcmd_usb0=setenv devnum 0; run usb_boot
bootdelay=1
bootfstype=fat
bootm_size=0x10000000
console=ttymxc0
cpu=armv7
devnum=0
devplist=1
devtype=mmc
distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
emmcargs=ip=off root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait
emmcboot=run setup; setenv bootargs ${defargs} ${emmcargs} ${setupargs} ${vidargs}; echo Booting from internal eMMC chip...; run m4boot && loa}
eth1addr=00:14:2d:3d:bc:18
ethact=FEC0
ethaddr=00:14:2d:2d:bc:18
ethprime=FEC
fdt_addr_r=0x82000000
fdt_board=eval-v3
fdt_fixup=;
fdt_high=0xffffffff
fdtcontroladdr=bff94a50
fdtfile=imx7d-colibri-emmc-eval-v3.dtb
initrd_high=0xffffffff
ip_dyn=yes
ipaddr=192.168.10.2
kernel_addr_r=0x81000000
kernel_file=zImage
loadaddr=0x80800000
mmc_boot=if mmc dev ${devnum}; then setenv devtype mmc; run scan_dev_for_boot_part; fi
netmask=255.255.255.0
nfsargs=ip=:::::eth0: root=/dev/nfs
nfsboot=run setup; setenv bootargs ${defargs} ${nfsargs} ${setupargs} ${vidargs}; echo Booting from NFS...;dhcp ${kernel_addr_r} && tftp ${fdt}
pxefile_addr_r=0x87100000
ramdisk_addr_r=0x82100000
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run ;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${de
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}extlinux/extlinux.conf; then echo Found ${prefix}extlinux/exi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found e
scriptaddr=0x87000000
sdargs=root=/dev/mmcblk1p2 ro rootwait
sdboot=run setup; setenv bootargs ${defargs} ${sdargs} ${setupargs} ${vidargs}; echo Booting from MMC/SD card...; run m4boot && load mmc 1:1 $}
serial#=02997272
serverip=192.168.10.1
setethupdate=if env exists ethaddr; then; else setenv ethaddr 00:14:2d:00:00:00; fi; tftpboot ${loadaddr} ${board}/flash_eth.img && source ${l}
setsdupdate=mmc rescan && setenv interface mmc && fatload ${interface} 0:1 ${loadaddr} ${board}/flash_blk.img && source ${loadaddr}
setup=setenv setupargs console=tty1 console=${console},${baudrate}n8 ${memargs} consoleblank=0
setupargs=console=tty1 console=ttymxc0,115200n8 consoleblank=0
setupdate=run setsdupdate || run setusbupdate || run setethupdate
setusbupdate=usb start && setenv interface usb && fatload ${interface} 0:1 ${loadaddr} ${board}/flash_blk.img && source ${loadaddr}
soc=imx7d
splashpos=m,m
updlevel=2
usb_boot=usb start; if usb dev ${devnum}; then setenv devtype usb; run scan_dev_for_boot_part; fi
vendor=toradex
vidargs=video=mxsfb:640x480M-16@60
videomode=video=ctfb:x:640,y:480,depth:18,pclk:39722,le:48,ri:16,up:33,lo:10,hs:96,vs:2,sync:0,vmode:0
Environment size: 4579/8188 bytes
Colibri iMX7 #
