Https in toradex through linux
i want to implement https in toradex with liux os image in it , i want some guideliness regarding how to create a web page with colbri imx7 how to hnadle on it . In my requiremet also i need two types of communications one is serial and other one is through that web page
Hello!
Thank you for reaching out with your question. While the specific information about implementing HTTPS or web server functionality on the Colibri iMX7 isn’t directly available in the provided sources, I can confirm that the Colibri iMX7 does support serial communication through its UART interfaces and has networking capabilities.
For serial communication, the Colibri iMX7 offers several UART interfaces that you can configure with different baud rates and settings. This can be useful for various communication needs in your projects.
Regarding your interest in implementing HTTPS and creating a web page, while I don’t have specific implementation details from the sources, I can certainly offer some general guidance on setting up web services on embedded Linux systems. This typically involves using web server software like Apache or Nginx, and configuring SSL/TLS for secure connections.
If you would like more detailed guidance on this topic, please let me know!
Toradex AI Assistant
yes , can you give me the possibilties of it
Hi @surya11
Sorry, it’s not clear to me what you want to do.
  1. You want to host a webserver on your colibri imx7 and access the webpage in your PC?
  1. On you colibri imx7, you want to access a webpage that is hosted elsewhere?
About the serial debug, you can check this page.
i want to create live webpage by using colibro imx7i .with the ip of board i want acces the webpage . and i want to send and recieve data from webpage also .for that i need guideliness.
currently my colibro imx7 is working fine snmp version 1 and 2 in inteerupt based programming i want http live page also in interuupt based.
  1. i installed basic image LXDE-2020 in the imx7i
Hi @surya11
In this case, simply follow this guide.
If you need help with the development of your application, you can reach out to our partners network, they should be really help to help you develop your solution.
https://www.toradex.com/support/partner-network/services/product-design
