I took the LinuxImageV2.6 and replaced meta-qt5 (QT 5.5) with the current one from github (QT 5.7).
Everything compiled successfully and the image works but I’m having a problem getting qtquick programs to work.
Every program crashes on startup with the message:
Cannot find EGLConfig, returning null config
Unable to find an X11 visual which matches EGL config 0
I think this is because the qt library and all programs that use it are linked against libGL instead of libGLESv2.
ldd gives this (output from a QT program):
libGL.so.1 => /usr/lib/libGL.so.1 (0x40d64000)
but I think it should be like this (output from a testprogram that does not use QT):
libEGL.so.1 => /usr/lib/libEGL.so.1 (0x40077000)
libGLESv2.so.2 => /usr/lib/libGLESv2.so.2 (0x40234000)
The qtbase configure from qt-meta(5.5) shows this:
OpenGL / OpenVG:
EGL .................. yes
OpenGL ............... yes (OpenGL ES 2.0+)
OpenVG ............... no
The configure from (5.7) shows this though:
OpenGL / OpenVG:
OpenGL ............... desktop
The file stuff/meta-toradex/recipes-qt/qt5/qtbase_%.bbappend
contains the line:
PACKAGECONFIG_GL_tegra = "gles2"
The image is built for a Colibri-T30.
Does anyone know why qtbase configure chooses desktop gl instead of gles2?
