Howto add fonts
I’m an openembedded newby. I’ve succesfully build the angstrom-qt5-x11-image (2.7-r0) which includes the Smarthome QT5 demo. I’ve noticed the text is completely missing in this demo so I assume there are no fonts installed in this image. The angstrom-qt5-image does not have a ttf directory (/usr/share/fonts) for example which is available in the angstrom-lxde-image. Which recipe should I add to my config so the fonts will also be included in the image? I’ve tried for example to add IMAGE_INSTALL_append = " ttf-liberation" but then I will get the following error:
Any idea what I should add so the fonts will be included??
Chris
Build Configuration:
BB_VERSION        = "1.32.0"
BUILD_SYS         = "x86_64-linux"
NATIVELSBSTRING   = "Ubuntu-16.04"
TARGET_SYS        = "arm-angstrom-linux-gnueabi"
MACHINE           = "colibri-imx6"
DISTRO            = "angstrom"
DISTRO_VERSION    = "v2016.12"
TUNE_FEATURES     = "arm armv7a vfp thumb neon       callconvention-hard"
TARGET_FPU        = "hard"
meta-angstrom     = "HEAD:ee90314737ce65dcc902a75ea7a1941bb38401aa"
meta-toradex-nxp  = "HEAD:ee77ef53d35284bcacc77e849dd30a36fe263ef2"
meta-freescale    = "HEAD:6ec09e6a0f09d1cb9c3761b339590c0a0baeeeb3"
meta-freescale-3rdparty = "HEAD:69ed94bb781a9c1bfbba4fb3026e4cbf3a194878"
meta-toradex-tegra = "HEAD:6363c6fcf4d7f0cb7dfc4b2e7f680e274c45d207"
meta-jetson-tk1   = "HEAD:e8b87fe8da7c6fcffa37ab245f50082953cc1ee1"
meta-toradex-bsp-common = "HEAD:05faa6a4346eeb7631fe72bcbb9aa7d414bee791"
meta-linaro-toolchain = "HEAD:407fe60740240b3115531cbed129f1e186bfbe3e"
meta-oe
meta-efl
meta-gpe
meta-gnome
meta-xfce
meta-initramfs
meta-systemd
meta-networking
meta-multimedia
meta-python       = "HEAD:1efa5d623bc64659b57389e50be2568b1355d5f7"
meta-lxde         = "HEAD:92f007c5b9b6ab48433b2049c32fc26b056b9159"
meta-browser      = "HEAD:1edcce7791b4cee9a515c1f11b351753a4f8b12e"
meta-qt4          = "HEAD:2c7f8df9039be498f8a2232d1428adb7f4e5e800"
meta-qt5          = "HEAD:9aa870eecf6dc7a87678393bd55b97e21033ab48"
meta-freescale-distro = "HEAD:ae27e8a8a068b960d6c1219f50b2e8ccc97f0bea"
meta-toradex-demos = "HEAD:9fa810182cbb085554ad3a596db6dbf1fc9a0a73"
meta              = "HEAD:c8d96b10ee3bc2eae0fd269d2564286fd0bc82ed"
WARNING: /extssd/toradex/oe-core/build/../layers/meta-toradex-nxp/recipes-kernel/linux/linux-toradex_4.1-2.0.x.bb.do_deploy is tainted from a forced run                 | ETA:  0:00:16
Initialising tasks: 100% |###############################################################################################################################################| Time: 0:00:19
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: angstrom-qt5-x11-image-V2.7-r0 do_rootfs: Unable to install packages. Command '/extssd/toradex/oe-core/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/opkg --volatile-cache -f /extssd/toradex/oe-core/build/tmp-glibc/work/colibri_imx6-angstrom-linux-gnueabi/angstrom-qt5-x11-image/V2.7-r0/opkg.conf -t /extssd/toradex/oe-core/build/tmp-glibc/work/colibri_imx6-angstrom-linux-gnueabi/angstrom-qt5-x11-image/V2.7-r0/temp/ipktemp/ -o /extssd/toradex/oe-core/build/tmp-glibc/work/colibri_imx6-angstrom-linux-gnueabi/angstrom-qt5-x11-image/V2.7-r0/Colibri_iMX6_LinuxImage-qt5V2.7/rootfs  --force_postinstall --prefer-arch-to-version   install xserver-xorg-utils connman-client systemd gstreamer1.0-plugins-base-audioresample gstreamer1.0-plugins-imx v4l-utils lsof xserver-xorg gstreamer1.0-plugins-base-ogg angstrom-feed-configs xdg-utils gstreamer1.0-plugins-good-wavenc i2c-tools libxdamage1 linux-firmware-ralink connman-plugin-wifi hdparm libusbg busybox gstreamer1.0-plugins-base-ivorbisdec memtester angstrom-packagegroup-boot connman-systemd update-alternatives-opkg e2fsprogs mtd-utils libgsf evtest gstreamer1.0-plugins-good-autodetect devmem2 libpcre1 alsa-utils xserver-xorg-extension-extmod ldd imx-gst1.0-plugin gpio-export stress qt5-x11-free-systemd lmbench imx-gst1.0-plugin-gplay libxinerama1 setxkbmap fontconfig-utils connman xserver-xorg-extension-dbe gstreamer1.0-plugins-base-typefindfunctions crda gstreamer1.0-plugins-base-videotestsrc file ptpd nbench-byte alsa-utils-amixer python-flask gstreamer1.0-plugins-good-audioparsers linuxptp xf86-video-imxfb-vivante rt-tests gstreamer1.0-plugins-good-wavparse iproute2 canutils iperf gstreamer1.0-plugins-good-matroska joe xrdb minicom gstreamer1.0-plugins-base-theora makedevs linux-firmware-rtl8192cu e2fsprogs-mke2fs alsa-utils-aplay qtsmarthome dosfstools packagegroup-qt5 udev e2fsprogs-tune2fs trdx-oak-sensors scrot libxcursor1 iperf3 sqlite3 gstreamer1.0-plugins-base-alsa aspell alsa-states nfs-utils-client gstreamer1.0-plugins-good-avi grep e2fsprogs-resize2fs fs-init tinymembench timestamp-service xset opkg zeroconf connman-plugin-ethernet opkg-config-base gstreamer1.0-plugins-good-udp openssh-sftp gstreamer1.0-plugins-good-isomp4 xorg-minimal-fonts packagegroup-basic gstreamer1.0-plugins-good-rtpmanager ttf-liberation xauth gstreamer1.0-plugins-base-vorbis eglinfo-x11 gstreamer1.0 gstreamer1.0-plugins-good-video4linux2 unclutter gstreamer1.0-plugins-good-rtp gstreamer1.0-plugins-base shadow u-boot-toradex-fsl-fw-utils libxvmc bzip2 connman-plugin-loopback udev-extra-rules gstreamer1.0-plugins-good-id3demux xhost libfontconfig1 gstreamer1.0-plugins-base-audioconvert gstreamer1.0-plugins-base-ximagesink gstreamer1.0-plugins-base-audiotestsrc gdbserver libopencl-mx6 curl libxres1 ethtool mimetypes libxcomposite1 gstreamer1.0-plugins-good-deinterlace bash mime-support packagegroup-fsl-gpu-libs openssh-scp libpcreposix0 util-linux-fstrim imx-gst1.0-plugin-grecorder packagegroup-base-extended xf86-input-evdev xserver-common xcursor-transparent-theme' returned 255:
Collected errors:
 * opkg_prepare_url_for_install: Couldn't find anything to satisfy 'ttf-liberation'.
ERROR: angstrom-qt5-x11-image-V2.7-r0 do_rootfs: Function failed: do_rootfs
ERROR: Logfile of failure stored in: /extssd/toradex/oe-core/build/tmp-glibc/work/colibri_imx6-angstrom-linux-gnueabi/angstrom-qt5-x11-image/V2.7-r0/temp/log.do_rootfs.28812
ERROR: Task (/extssd/toradex/oe-core/build/../layers/meta-toradex-demos/recipes-images/images/angstrom-qt5-x11-image.bb:do_rootfs) failed with exit code '1'
NOTE: Tasks Summary: Attempted 6720 tasks of which 6719 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory
Hi
Please have a look here.
Max
Sorry for my late reply but I’ve overlooked that part. Thanks
