I am trying to change my dtb file using uboot environment variable fw_setenv fdt_file custom-devicetree.dtbbut after reboot again the old .dtb file loaded. Then I found that the boot partition is readonly and I source the script source /etc/profile.d/fw_unlock_mmc.sh to make boot partition writable. I tried again to reboot and faced the same problem.
my goal is to write the env_vairable only using fw_setenv fdt_file
u boot version :U-Boot 2015.04 (Dec 02 2015 - 09:35:08)
content from /etc/fw_env.config
# Configuration file for fw_(printenv/setenv) utility.
# Up to two entries are valid, in this case the redundant
# environment sector is assumed present.
# Device offset must be prefixed with 0x to be parsed as a hexadecimal value.
# On a block device a negative offset is treated as a backwards offset from the
# end of the device/partition, rather than a forwards offset from the start.
# Colibri iMX6/Apalis iMX6
# U-Boot environment is stored at the end of the first eMMC boot partition
# hence use a negative value. The environment is just in front of the config
# block which occupies the last sector (hence -0x200)
# Block device name Device offset Env. size
/dev/mmcblk0boot0 -0x2200 0x2000
I found that my new kernel fw_env.config was different from the old kernel. Is there any possibility to change environment variables with out updating the u-boot ?
I modified the fw_env.config and changed the fdt_file.
Now, after rebooting the file changed to my custom.dtb in kernel, but not updated in the U-boot
Saving Environment to MMC...
Writing to MMC(0)... done
Booting from internal eMMC chip...
reading imx6q-apalis-eval1.dtb
49952 bytes read in 19 ms (2.5 MiB/s)
reading uImage1
4844728 bytes read in 147 ms (31.4 MiB/s)
## Booting kernel from Legacy Image at 11000000 ...
Image Name: Linux-4.1.35-v2.7b1+gc117783
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 4844664 Bytes = 4.6 MiB
Load Address: 10008000
Entry Point: 10008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 12000000
Booting using the fdt blob at 0x12000000
Loading Kernel Image ... OK
Using Device Tree in place at 12000000, end 1200f31f
Starting kernel ...
I have also updated my U-boot version to 2016.11+fslc+g22e68cb (Aug 14 2017 - 11:28:45 +0200) and tried with both modifying and without modifying /etc/fw_env.config. I experienced the same results.
I don’t know what exactly goes wrong in your case. You seem to mix various components of the Image from different versions which do not work together.
So I sum up here what is involved in the U-Boot environment handling.
U-Boot
U-Boot is reading its environment from the eMMC. This used to be in the user area of the eMMC at byte address 0x80000 and with with Linux Image V2.5 Beta 2 this moved to the first boot area of the eMMC, 0x2200 before the end of that partition. If U-Boot does not find a valid checksum it uses defaults compiled into the U-Boot binary.
Note that by default we do not store an U-Boot environment ex. factory and rely on the defaults compiled in.
User Space Tools, e.g. the relevant files in the rootfs
fw_printenv and fw_setenv use the file ‘/etc/fw_env.config’ to get the U-Boot environment location. The fw_printenv/fw_setenv binaries also fall back to defaults in the binary if they do not find a valid checksum in the eMMC.
Kernel
The kernel needs to be able to read and write the eMMC location were the environment is stored. I think that only very old kernel versions could be affected. But the boot area is only accessible read only by default, setting this to rw can be accomplished by executing ‘source /etc/profile.d/fw_unlock_mmc.sh’. On a serial getty this is done automatically when one does login.
So, you have to make sure that your version of U-Boot and the file ‘/etc/fw_env.config’ agree on the location were the environment is stored.
Additionally, you have to either save the environment once from U-Boot before using the fw_printenv/fw_saveenv tools OR you must be able to live with the default environment stored in the fw_saveenv binary.
