Hi
I have a colibri T20 and Iris Carrier Board with WinCE7. I need to save some logs to the Micro SD card. How to write/read data from SD Card.?
Hi
Writing on SD CARD is same as writing on other memory drives like USB HD, FlashDisk you just need to use standard file handling functions in C, for your reference you can check this page: link text (fOpen, fClose, getc) and give correct memory location "/SD CARD/ "in your application.
