Dear all,
i’m working with the following configuration: Apalis iMX8QM 4GB WB IT V1.1D Ixora Carrier Board V 1.2A DISTRO_VERSION = “4.0.10” DISTRO_CODENAME = “kirkstone”
Is there any reference information on building with opencl Yocto for Machine Learning?
Best regards, sjjin
Hi @sjjin, have you checked this?
Can you try adding the following to the local.conf?
IMAGE_INSTALL_append = " imx-gpu-viv fsl-gpu-sdk"
However, we have customers reporting that CPU performance is better than GPU: How to build OpenCL programming environment in yocto - #5 by deepimpact
Hi, @alvaro.tx ,
This has been confirmed.
As you informed me to local.conf We will add it.
IMAGE_INSTALL_append = "imx-gpu-viv fsl-gpu-sdk"
What I’m hoping to do is wonder if there is an opencl reference like this.
