I am working on Colibri Evaluation Board v3.2b with Colibri imx8QXP 2GB WT IT V1.0 A.
On evaluation board X11 jumper array have X11.A and X11.B male pin shorted together than signals are available on external peripherals.
My question if jumpers not present then signal are available on (x10 and x12) both header or not ?
How to use X10 and x12 header pins?
Jumper X10 provides SODIMM breakout and X12 is Function Tap which means if you remove jumper x11, the peripheral functionality will be disabled i.e UARTs, SDcard, etc. e.g if you remove x11.2(SODIMM 19), UART_C_RXD will not work.
