How to toggle/reset gpio from device tree imx7d
Hi @jaski.tx
I am using Colibri iMX7D 1GB eMMC SOM with Kernel 3.0.
I have connected one device’s reset pin to GPIO2_IO1, How can I toggle/reset (from low to high) device before booting linux from device tree.
Or any other suggestions on this.
Thank you
Neeraj
Could you please help
I’d recommend to toggle pin at U_Boot level. You can add it to the end of int board_init(void). Please check how back light pin get inited and toggled.
Hi @alex.tx,
Thank you for your suggestions.
Let me try below:
git clone -b toradex_2019.07 git://git.toradex.com/u-boot-toradex.git
Do required modifications
make colibri_imx7_defconfig
make colibri_imx7_emmc_defconfig
make u-boot.imx
Copy u-boot.imx image into Colibri-iMX7-eMMC_Console-Image-Tezi_3.0b4 and flash into eMMC using EasyInstaller?
Please suggest if i am missing anything.
Thank you
Neeraj
Please follow this article.
Adding solution to toggle GPIO from u-boot
./board/toradex/colibri_imx7/colibri_imx7.c
gpio_request(33, “device-reset”);
gpio_direction_output(33, 1);
//set low
gpio_set_value(33, 0);
mdelay(100);
//set high
gpio_set_value(33, 1);
You need to do a pin muxing and request a GPIO and set direction first. Please check how back light pin get inited and toggled. colibri_imx7.c « colibri_imx7 « toradex « board - u-boot-toradex.git - U-Boot bootloader for Apalis and Colibri modules
hi @neeraj.verma
Is the issue solved?
Hi @jaski.tx ,
Thank you for following up on this.
Actually the question I asked is answered but not in a way what I was looking far, I am able to toggle gpio from u-boot not from device tree.
I plan to create a new thread.
Thank you
Neeraj
Thanks for update.
