How to Store Docker Data on an External Storage Device here: SSD
Hello everyone,
We would like to move the docker directory to an SSD.
There is a guide that doesn’t work for me. See here
I partitioned a 256 GB SSD into 2 parts and named the first partition ‘docker’.
It seems as if there is now an automation that mounts the docker partition to /media/docker.
Am I right?
And if, yes … how does it works?
my tdx-info:
Software summary
Kernel version:           5.15.148-6.6.1+git.23a8e831749d #1-TorizonCore SMP PREEMPT Thu Feb 29 20:25:21 UTC 2024
Kernel command line:      pci=nomsi root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.0/torizon/0215ecb778c505465daba1f372ede65642cfa6fbf3c0c8acda846b8236cd0630/0
Distro version:           VERSION_ID=6.6.1-build.12
Hostname:                 apalis-imx8-07278333
Hardware info
HW model:                 Toradex Apalis iMX8QM V1.1 on Apalis Ixora V1.2 Carrier Board
Toradex version:          0037 V1.1E
Serial number:            07278333
Best
Gerald
Greetings @gerko,
Just want to clarify to make sure I understand your current situation.
Are you saying that your SSD was auto-mounted correctly to the device filesystem. Or did it not? The correct behavior is that removable media is automatically mounted in Torizon OS under /media somewhere. This is assuming Torizon OS has support for the type of device you are attaching and support for the filesystem type present on that device.
We make use of udisks2 to manage the detection and automatic mounting of removable media in Torizon OS.
That explains everything!
So I don’t have to edit /etc/fstab.
Thank you!
Glad I could help clarify.
