How to achieve this at startup.
I tried above command without success.
The rtsp stream is okay. But the above command results in black screen. The top command shows x-server and gst-play are running.
Any help would be appreciated.
Thank you.
Dear jaski, Thanks for this information about startup, but when I manually try to run gst-play-1.0 with rtsp stream the output is black screen. What could be the reason behind it ? Am I missing some plugins/libraries ?
Yes even manually trying to play this stream does not work, I also tried using ~/.xinitrc in home directory, gst-play-1.0 does starts as it is shown by top command but it does not show the rtsp video, we can only see a black screen and mouse pointer in x shape.
OK, so “gst-launch with startx” has absolutely nothing to do with what you are in effect asking for. You are in general unable to play an RTSP stream, correct? How do you know that whatever stream you are trying to play is even correct? Did you have a look at the following article on our developer website already? OK, admittedly that one is about RTP and not RTSP. I guess if RTSP support is really missing in our regular demo images you may easily add it to your custom image. Looks like gst-rtsp may be part of the meta-multimedia layer. Alternatively, you may try running JetPack which comes with RTSP support.
