how to setup simultaneous display (lvds + hdmi) for i.mx8m plus in linux os
Hello! Setting up simultaneous display output on both LVDS and HDMI with the Verdin iMX8M Plus under Linux is fully supported. Here’s a step-by-step guide to help you achieve this:
1. Enable Device Tree Overlays
You need to enable both the HDMI and LVDS overlays. On TorizonCore or Toradex Reference Images, do this by editing the overlays.txt file on the /boot partition:
# Backup the current overlays.txt (optional)
cp /boot/overlays.txt ~/overlays_backup.txt
# Add overlays for HDMI and LVDS
echo "fdt_overlays=verdin-imx8mp_hdmi_overlay.dtbo verdin-imx8mp_lvds_overlay.dtbo" > /boot/overlays.txt
sync
reboot
2. HDMI Output
- HDMI uses automatic monitor detection (EDID/DDC), so usually no further configuration is needed.
- If you want to force a specific resolution, edit your kernel command line (e.g., in U-Boot):
video=HDMI-A-1:1280x720
3. LVDS Display Setup
LVDS requires more specific configuration for timings and data-mapping according to your LCD panel. In your device tree overlay, make sure to set the fsl,data-mapping and fsl,data-width properties to match your display:
For example:
- For an 18-bit JEIDA panel:
fsl,data-mapping = "spwg"; fsl,data-width = <18>; - For a 24-bit VESA panel:
fsl,data-mapping = "spwg"; fsl,data-width = <24>; - For a 24-bit JEIDA panel:
fsl,data-mapping = "jeida"; fsl,data-width = <24>;
Full list of options and panel configuration
4. Verify Both Displays
After rebooting, check if both LVDS and HDMI displays are detected:
modetest -M imx-drm
This tool will list all connectors (HDMI-A-1, LVDS-1), their modes, and current configuration.
5. Additional Tips
- The i.MX 8M Plus can drive all three outputs (HDMI, LVDS, MIPI-DSI) at once, with certain performance limits (e.g., 2x 1080p60 + 1x 4kp30).
- Use TorizonCore Builder or Yocto if you need to customize overlays or device trees further.
For more details and examples, please refer to the official Toradex Display Output documentation:
Hi @GeorgeChang
Have you tested this?
