Please suggest the setting parameters of the wince6.0 registry to setup a ad-hoc network on VF50 module using LM816 wi-fi module. It is working good when used on a wi-fi network.
Dear @Mania,
Could you try the following documentation similar steps and let us know what is the output with details step by steps? It will help us to look at the issue specifically.
https://www.slideshare.net/guesta5887e6b/rt2870-software-release-note-for-windows-ce, page no : 16
If it is not working with this driver then try this driver.
