How do I set up the Verdin plus to always turn on when power is applied (ie no need for power switch)
To configure a Verdin module to automatically power on when power is applied, you can utilize the U-Boot environment variables to control the power-on behavior. This process involves setting the bootdelay
variable to a specific value that instructs the module to start without waiting for any user input.
Here’s a step-by-step guide to achieve this:
Access U-Boot: Connect to your Verdin module through a serial console or SSH, depending on your setup. You’ll need to interrupt the boot process to access the U-Boot command line. This is typically done by pressing any key during the early stages of the boot process.
Modify U-Boot Environment Variables: Once in U-Boot, use the following command to set the
bootdelay
variable to 0. This change ensures that U-Boot will not wait for any user input and will proceed with the boot process immediately.setenv bootdelay 0
Save Changes: After setting the
bootdelay
variable, you need to save the changes to make them persistent across reboots. Use the following command to save the environment variables:saveenv
Reboot: Now that the changes are saved, you can reboot your module. It should now automatically power on and boot up when power is applied, without the need for pressing a power switch or any other input.
reset
Please note that this configuration will affect how you interact with the U-Boot environment in the future. With bootdelay
set to 0, you won’t have the usual window to interrupt the boot process for accessing U-Boot commands directly. If you need to change this behavior back or modify other U-Boot settings later, you will need to use a specific method for your module to force it into U-Boot, such as using a hardware mechanism or a specific software command if available.
This approach is generally applicable to Verdin modules, but it’s always a good idea to refer to the specific documentation for your module version and the U-Boot version it’s running, as commands and procedures may vary slightly.
Best regards, Toradex AI Assistant
ITTIA DB SQL for Device Data Management | Toradex Developer Center.
The module automatically transitions to the running mode when the VCC main power rail is
applied to the module. In other words, all Verdin modules are ramping up the power rails and
boot the system when the VCC is applied.
If you are referring to a particular carrier board, please refer to its datasheet. For example, on the Verdin Development Board, you can use the Always-ON Jumper (JP7).
I’m sorry, but the context provided does not include specific instructions on how to set the Verdin module to automatically power on when power is applied. You may need to refer to the Verdin SoM Family Documentation or consult Toradex support for detailed guidance on this configuration.
