how can i set the Admin Password without actually accessing the Webinterface?
I want to “production programm” the Devices with a specific password.
But as it seems in the Registry the Password is encoded differently.
[HKEY_LOCAL_MACHINE\Comm\Security\UserAccounts\ADMIN]
So if you copy the key from one Box to the other, it does not work.
Can you tell me how to achieve this?
Best regards, Stefan
See a similiar discussion here:
https://social.msdn.microsoft.com/Forums/en-US/d2315024-8cf7-406d-9798-138a52b3439b/wec7-default-system-password?forum=winembplatdev
The result of this discussion is:
“I created a small application which sets the password and reboot the device. This executable is embedded into the OS using a .bib file and placed into the /Windows/StartUp folder using a .dat file.”
@Frax222 : Thank you for the fast reply. But i’m not sure how to create a small Application for this purpose. For me it sounds like it is embedded in the Windows CE7 Image?
Is it possible to create a .net Application which could do this once?
@jaski.tx : I’m sorry it was not the highest priority the last time. I was not sure how to create the “native C” application. I Used to use the VS2008 Toolchain. How can i create a native C application for Windows CE7?
Hi @Stefan.P ,
You can try this prebuilt AddUser.exe which just calls NTLMSetUserInfo():
https://share.toradex.com/j90btjlga8r46ob
here is the source:
#include <windows.h>
#include "Ntlmssp.h"
int _tmain(int argc, TCHAR *argv[], TCHAR *envp[])
NTLMSetUserInfo(argv[1],argv[2]);
return 0;
So to use the prebuilt executable just pass username and password as a command line param
