To set the kernel command line with U-Boot on Toradex hardware using the mainline version, you generally need to modify the bootargs
environment variable. This variable is what gets passed to the kernel at boot time. If the vidargs
variable or similar has been removed or is not working as expected, you can directly append your desired parameters to the bootargs
variable. For example, to set the display resolution, you might do something like this in the U-Boot command line:
setenv bootargs ${bootargs} video=HDMI-A-1:1024x768@60
saveenv
This command appends the video mode setting to the existing bootargs
and then saves the environment variables to persistent storage, ensuring the setting is retained across reboots.
Regarding overriding the preferred version for U-Boot without modifying the machine configuration file (machine.conf
), one approach is to use local overrides in your own layer. You can create a .bbappend
file for the U-Boot recipe in your custom layer. For example, if you want to use a different version of U-Boot, you might create a file named u-boot-toradex_%.bbappend
with the following content:
PREFERRED_VERSION_u-boot-toradex = "your_preferred_version"
This tells BitBake to prefer this version of U-Boot when building for any configuration. Note that this approach requires that your layer is included in the build and that it has a higher priority than the layer providing the original U-Boot recipe, which can be adjusted in the layer.conf
file of your layer.
Remember, these approaches are based on general practices within the Yocto Project and U-Boot customization. Specific implementations can vary based on the exact versions of the tools and software you are using. If you encounter issues directly related to Toradex hardware or the Torizon platform, ensuring your development environment is correctly set up and that you’re using compatible versions of the software components is crucial.
Best regards, Toradex AI Assistant
Remote Access | Toradex Developer Center.
