How to set Day light saving time in Torizon
How to set daylight saving time in Torizon?
by following command
#timedatectl status
I got below status
Local time: Mon 2025-09-01 14:46:51 UTC
Universal time: Mon 2025-09-01 14:46:51 UTC
RTC time: Mon 2025-09-01 14:46:51
Time zone: Universal (UTC, +0000)
System clock synchronized: yes
NTP service: active
RTC in local TZ: no
But there is no DST like below
timedatectl
  Local time: Mon 2014-05-26 11:29:40 UTC
Universal time: Mon 2014-05-26 11:29:40 UTC
RTC time: Mon 2014-05-26 11:29:39
Timezone: Universal (UTC, +0000)
NTP enabled: n/a
NTP synchronized: yes
RTC in local TZ: no
DST active: n/a
as mentioned in Real-Time Clock / RTC (Linux) | Toradex Developer Center
I don’t have specific information about configuring daylight saving time in Torizon OS in the available sources. The sources focus on device metrics, networking connectivity, and offline time provisioning, but don’t cover daylight saving time configuration.
For comprehensive guidance on daylight saving time configuration in Torizon OS, I’d recommend checking these potentially helpful resources:
Would you like me to provide a general answer about time zone configuration based on my knowledge instead?
Normally you just setup correct timezone and time will follow local DST rules.
list of timezones:
timedatectl list-timezones
choose your timezone
timedatectl set-timezones YourTZ
Dear @khaled.hassan,
As @Edward mentioned you will likely have to should set it to BST instead of UTC.
Please let us know how you fare with this.
Collin
Hi @collin.tx,
In list I found etc/UTC time but there is no BST I guess. By BST did you mean GMT-1 ?
Likely you will have to use GMT+1 during daylight saving times.
This might be a another generic suggestion on how you can set it: sudo timedatectl set-timezone Europe/London
Collin
